I am very new in Arduino, enjoying an Uno (already spoiled another Uno) and an Mega2560. I tried to run a stepper motor and two dc motor with Mega 2560 and Arduino Shield Board. I wrote a code with the help of other codes available in internet.
the code is OK but while trying uploading in Mega the last line comes as,
"exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560."
I tried uploadding from a laptop with Windows10 and with another with Ubuntu 17.04.
In both the cases result is same.
I want help from experts for completing.
The complete reports from the computer is attatched below.
Thanks and Regards,
Rana Khan.
Compiling libraries...
Compiling library "Stepper"
Using previously compiled file: /tmp/arduino_build_486833/libraries/Stepper/Stepper.cpp.o
Compiling library "Adafruit_Motor_Shield_library"
Using previously compiled file: /tmp/arduino_build_486833/libraries/Adafruit_Motor_Shield_library/AFMotor.cpp.o
Compiling library "Adafruit_Motor_Shield_V2_Library"
Using previously compiled file: /tmp/arduino_build_486833/libraries/Adafruit_Motor_Shield_V2_Library/Adafruit_MotorShield.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/libraries/Adafruit_Motor_Shield_V2_Library/utility/Adafruit_MS_PWMServoDriver.cpp.o
Compiling library "Wire"
Using previously compiled file: /tmp/arduino_build_486833/libraries/Wire/Wire.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/libraries/Wire/utility/twi.c.o
Compiling library "PWMServo"
Using previously compiled file: /tmp/arduino_build_486833/libraries/PWMServo/PWMServo.cpp.o
Compiling library "Button"
Using previously compiled file: /tmp/arduino_build_486833/libraries/Button/Button.cpp.o
Compiling core...
Using previously compiled file: /tmp/arduino_build_486833/core/wiring_pulse.S.o
Using previously compiled file: /tmp/arduino_build_486833/core/WInterrupts.c.o
Using previously compiled file: /tmp/arduino_build_486833/core/hooks.c.o
Using previously compiled file: /tmp/arduino_build_486833/core/wiring.c.o
Using previously compiled file: /tmp/arduino_build_486833/core/wiring_pulse.c.o
Using previously compiled file: /tmp/arduino_build_486833/core/wiring_analog.c.o
Using previously compiled file: /tmp/arduino_build_486833/core/wiring_shift.c.o
Using previously compiled file: /tmp/arduino_build_486833/core/wiring_digital.c.o
Using previously compiled file: /tmp/arduino_build_486833/core/CDC.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/HardwareSerial.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/HardwareSerial0.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/HardwareSerial1.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/HardwareSerial2.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/HardwareSerial3.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/IPAddress.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/PluggableUSB.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/Print.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/WString.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/Tone.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/USBCore.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/WMath.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/main.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/abi.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/new.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/Stream.cpp.o
Using previously compiled file: /tmp/arduino_build_486833/core/core.a
Archiving built core (caching) in: /tmp/arduino_cache_27005/core/core_arduino_avr_mega_cpu_atmega2560_af1bdde207d6b3fbd1572c44677e2228.a
Linking everything together...
/home/rana/arduino-1.8.7/hardware/tools/avr/bin/avr-gcc -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o /tmp/arduino_build_486833/sketch_sep21a.ino.elf /tmp/arduino_build_486833/sketch/sketch_sep21a.ino.cpp.o /tmp/arduino_build_486833/libraries/Stepper/Stepper.cpp.o /tmp/arduino_build_486833/libraries/Adafruit_Motor_Shield_library/AFMotor.cpp.o /tmp/arduino_build_486833/libraries/Adafruit_Motor_Shield_V2_Library/Adafruit_MotorShield.cpp.o /tmp/arduino_build_486833/libraries/Adafruit_Motor_Shield_V2_Library/utility/Adafruit_MS_PWMServoDriver.cpp.o /tmp/arduino_build_486833/libraries/Wire/Wire.cpp.o /tmp/arduino_build_486833/libraries/Wire/utility/twi.c.o /tmp/arduino_build_486833/libraries/PWMServo/PWMServo.cpp.o /tmp/arduino_build_486833/libraries/Button/Button.cpp.o /tmp/arduino_build_486833/core/core.a -L/tmp/arduino_build_486833 -lm
/tmp/arduino_build_486833/libraries/Adafruit_Motor_Shield_V2_Library/Adafruit_MotorShield.cpp.o (symbol from plugin): In function Adafruit_MotorShield::begin(unsigned int, TwoWire*)': (.text+0x0): multiple definition of microstepcurve'
/tmp/arduino_build_486833/libraries/Adafruit_Motor_Shield_library/AFMotor.cpp.o (symbol from plugin):(.text+0x0): first defined here
/home/rana/arduino-1.8.7/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
collect2: error: ld returned 1 exit status
Using library Stepper at version 1.1.3 in folder: /home/rana/arduino-1.8.7/libraries/Stepper
Using library Adafruit_Motor_Shield_library at version 1.0.0 in folder: /home/rana/Arduino/libraries/Adafruit_Motor_Shield_library
Using library Adafruit_Motor_Shield_V2_Library at version 1.0.5 in folder: /home/rana/Arduino/libraries/Adafruit_Motor_Shield_V2_Library
Using library Wire at version 1.0 in folder: /home/rana/arduino-1.8.7/hardware/arduino/avr/libraries/Wire
Using library PWMServo at version 2.1 in folder: /home/rana/Arduino/libraries/PWMServo
Using library Button at version 1.0.0 in folder: /home/rana/Arduino/libraries/Button
exit status 1
