Problem Uploading Wink
Which my next steps shoulв be after thу mistake below:
Arduino: 1.6.6 (Windows 7), Board: "Arduino Fio"
D:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "D:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Dimm\AppData\Local\Arduino15\packages" -tools "D:\Program Files (x86)\Arduino\tools-builder" -tools "D:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Dimm\AppData\Local\Arduino15\packages" -built-in-libraries "D:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Dimm\Documents\Arduino\libraries" -fqbn=arduino:avr:fio -ide-version=10606 -build-path "C:\Users\Dimm\AppData\Local\Temp\buildb48cf179db67a583bc24c7c8c87c7f6f.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "D:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino" ... "C:\Users\Dimm\AppData\Local\Temp\buildb48cf179db67a583bc24c7c8c87c7f6f.tmp/Blink.ino.elf" "C:\Users\Dimm\AppData\Local\Temp\buildb48cf179db67a583bc24c7c8c87c7f6f.tmp/Blink.ino.hex"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 30,720 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes. D:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CD:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b57600 -D -Uflash:w:C:\Users\Dimm\AppData\Local\Temp\buildb48cf179db67a583bc24c7c8c87c7f6f.tmp/Blink.ino.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "D:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8 Using Programmer : arduino Overriding Baud Rate : 57600 avrdude: ser_open(): can't open device "\.\COM8": Отказано в доступе.
avrdude done. Thank you.
avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x82 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail :
Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino Description : Arduino avrdude: stk500_recv(): programmer is not responding Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
