So I'm trying to upload a simple code that blinks a led on and off every second, to an ATMega328PU, using usbAsp. I managed to get the USBasp driver working, but now I'm running into something else. Here's the error I get when trying to use the "Upload using programmer" button in the Arduino IDE:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
Build options changed, rebuilding all
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
the selected serial port
does not exist or your board is not connected
You see, I'm getting a "device not found" error when the usbasp is disconnected, so something else must be to blame. Any help would be much appreciated.
