problem uploading
Arduino: 1.6.5 (Windows 7), Board: "Arduino Uno"
i am working on quad eventually i gave board reverse current and IC became hot and now i am not able to upload program again i am arriving with this error:
i replaced IC also..
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x01
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x01
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
please help me how to solve it
jiljain:
By 'quad' did you mean Arduino UNO?
By 'IC' did you mean the ATmega328P on the Arduino UNO?
By "i replace IC also.." do you mean that you replaced the ATmega328P with a new one?
If all those are true I would suspect your new ATmega328P does not have the right Arduino bootloader installed. You can get an ISP device from eBay for about $5. Look for USBasp or USBtiny. Find one with a 6-pin cable (often they come with 10-pin cables). That will let you burn a fresh bootloader.
