Hello guys
I am having problems uploading to my arduino uno r3
i am getting the following error code
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino/Genuino Uno"
Sketch uses 450 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\BHAVAY~1\AppData\Local\Temp\build6787089157224871632.tmp/sketch_oct03a.cpp.hex:i
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x21
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x21
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
The serial port is connected fine and there is no problem in the usb,
The drivers are latest.
My reset buttton dosent do anything.
Please help
