I'm trying to upload a sketch to Sparkfun Lilypad mp3 the sketch compiles fine. Sparkfun says to select “Arduino Pro or Pro Mini (3.3V/8MHz) w/ATmega 328”.
Here is the error message I'm getting
Arduino: 1.6.10 (Windows 8.1), Board: "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
In file included from C:\Program Files (x86)\Arduino\libraries\SdFat/ArduinoStream.h:26:0,
from C:\Program Files (x86)\Arduino\libraries\SdFat/SdFat.h:40,
from C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino:11:
C:\Program Files (x86)\Arduino\libraries\SdFat/bufstream.h:64:25: warning: unused parameter 'off' [-Wunused-parameter]
bool seekoff(off_type off, seekdir way) {return false;}
C:\Program Files (x86)\Arduino\libraries\SdFat/bufstream.h:64:38: warning: unused parameter 'way' [-Wunused-parameter]
C:\Program Files (x86)\Arduino\libraries\SdFat/bufstream.h:128:25: warning: unused parameter 'off' [-Wunused-parameter]
C:\Program Files (x86)\Arduino\libraries\SdFat/bufstream.h:128:38: warning: unused parameter 'way' [-Wunused-parameter]
In file included from C:\Program Files (x86)\Arduino\libraries\SdFat/SdFat.h:40:0,
C:\Program Files (x86)\Arduino\libraries\SdFat/ArduinoStream.h:74:25: warning: unused parameter 'off' [-Wunused-parameter]
C:\Program Files (x86)\Arduino\libraries\SdFat/ArduinoStream.h:74:38: warning: unused parameter 'way' [-Wunused-parameter]
C:\Program Files (x86)\Arduino\libraries\SdFat/ArduinoStream.h:79:25: warning: unused parameter 'pos' [-Wunused-parameter]
bool seekpos(pos_type pos) {return false;}
C:\Program Files (x86)\Arduino\libraries\SdFat/ArduinoStream.h:110:25: warning: unused parameter 'off' [-Wunused-parameter]
C:\Program Files (x86)\Arduino\libraries\SdFat/ArduinoStream.h:110:38: warning: unused parameter 'way' [-Wunused-parameter]
C:\Program Files (x86)\Arduino\libraries\SdFat/ArduinoStream.h:111:25: warning: unused parameter 'pos' [-Wunused-parameter]
C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino: In function 'void setup()':
C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino:46:6: warning: unused variable 'x' [-Wunused-variable]
int x, index;
C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino:48:7: warning: unused variable 'result' [-Wunused-variable]
byte result;
C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino: In function 'void loop()':
C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino:109:6: warning: variable 't' set but not used [-Wunused-but-set-variable]
int t; // current trigger
C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino:110:13: warning: unused variable 'last_t' [-Wunused-variable]
static int last_t; // previous (playing) trigger
C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino:111:6: warning: unused variable 'x' [-Wunused-variable]
int x;
C:\Users\Clint\Documents\Arduino\sketch_sep03b\sketch_sep03b.ino:112:7: warning: unused variable 'result' [-Wunused-variable]
byte result;
Sketch uses 11,388 bytes (37%) of program storage space. Maximum is 30,720 bytes.
Global variables use 1,070 bytes (52%) of dynamic memory, leaving 978 bytes for local variables. Maximum is 2,048 bytes.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
