Hello,
My daughter received this for Christmas and loves it!!!
So we are on lesson 4 RGB LED and when we attempt to upload the sketch we get the "problem uploading to board. http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions. I went to the guide but was unable to find a resolution.
I'm assuming this is when in Lesson 4, the light just went on once and not in and out.
Any advice and/or suggestions is greatly appreciated.
Uncheck the checkbox next to “Show verbose output during: compilation”
Check the checkbox next to "Show verbose output during: upload
Click “OK”
Sketch > Upload
After the upload fails, you’ll see a button on the right side of the orange bar “Copy error messages” (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum’s code tags markup to your reply.
Press “Ctrl + V”. This will paste the upload output between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
Thank you so much for the reply! Here is the message.
Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1422 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 15 bytes (0%) of dynamic memory, leaving 2033 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\jende\AppData\Local\Temp\arduino_build_403968/RGB_LED.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
You need to select the COM port of your Arduino board from the Arduino IDE's Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
Unplug your Arduino board from the computer.
Tools > Port
Note the ports, if any, listed in the menu.
Close the Tools menu
Plug your Arduino board into the computer.
Tools > Port - The new port listed in the menu is your Arduino board.
Thank you. When I unplugged the Arduino there was no port to select. I plugged it back in and the port that shows is:
COM3 (Ardunio Mega)
I then tried to upload the sketch for Lesson 4 and still got the error message:
Using Port : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xdb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xdb
