hello, I tried making a l293d 4wd Arduino Uno obstacle avoider,
it worked the first time but when I decided to switch the motor connections then my 16v battery accidentaly touched one of the motor connection terminals then it suddenly stopped working!
nothing is moving. I tried uploading again but it didn’t work it takes a long time to upload then gives me this error message:
Arduino: 1.8.13 (Windows 10), Board: “Arduino Uno”
Sketch uses 5314 bytes (16%) of program storage space. Maximum is 32256 bytes.
Global variables use 124 bytes (6%) of dynamic memory, leaving 1924 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
“Show verbose output during compilation”
option enabled in File → Preferences.
I got all the wiring details and code from here:
