Problem using 32 kHz clock crystal with a Atmega 328 (device signature:0x000000)
I am trying to build a digital watch.I intend to use the 32 kHz crystal for timer2 in async mode. I know I should have used a 328P instead of a regular 328 but I didn't have one on hand and buying stuff during the coronavirus is difficult. So I decided to go with the 328 for prototyping. I am using an Arduino Uno board as ISP. I loaded the Pro mini 8Mhz bootloader on it and it worked fine. Then I moved ahead with changing the fuse bits. I set the fuse bits to HIGH : 0xDA LOW: 0xE2 Extended: 0xFF. After changing the fuse bits I rechecked the chip using avrdude command and it had the desired fuse bits. The chip previously had a Blink sketch prior to change the fuse bits and it was working fine. But when I tried to upload another program using Arduino IDE i got the avrdude : device signature : 0x000000 error. The blink sketch had also been erased. Afterwards when I rechecked using command line it showed the same error message and then showed that the fuse bits were all 0x00.
I have tried :-
  1. Using a different power supply other than the Uno.
  2. changing the clock crystal
  3. Lowering the baud rates
  4. Attaching decoupling caps on power pins and loading caps on the crystal pins (although for a 32 KHz, I am told that these are not necessary)
Avrdude also gives the error message programmer not responding whenever any other command is passed.
I can confirm that there is a bootloader on the chip as any LED connected from SCK pin to ground will flash whenever I reset the chip.
I have to tell this beforehand:** I do not have an oscilloscope & I do not have any other ISP**.
Please help.
Thank you.
How did you check it, via ISP?
But when I tried to upload another program using Arduino IDE...
Using standard Arduino USB/serial interface?
You have changed boot region size to 2k. This means the boot address changed also. Did you load a new bootloader?
