Problem using a variable to switch off DC motor, using H-Bridge
try
  sylvacRad.trim()
  FloatRad = sylvacRad.toFloat();
trim() removes leading and trailing white space newlines carriage returns tabs etc
Actually Arduino String toFloat() is fine with the sylvacRad.trim(); statement
As Bob says remove the float from the FloatRad = sylvacRad.toFloat();
Hi all!
Last programming question and I am done here! Thank you everyone for your help!
I need to use case switch statements to trigger different void codes at specific measurement values.
I want the product to do this in order : {MoveUp();--- TopDownBacklash();--- WaitTop();---MoveDown();---BottomUpBacklash();----WaitBottom();}
And repeat this forever, currently with my code it MovesUp(); without moving to TopDownBacklash(); this is far from the loop I'm seeking. I am using a global int (num) to trigger what switch case to use. I may be doing this wrong, help is again much appreciated thank you all;
int enA = 9;
int in1 = 8;
int in2 = 7;
String sylvacRad;
float FloatRad;
const float Hthreshold = 25.2245;
const float HthresholdOS = 25.2255;
const float Lthreshold = 24.8853;
const float LthresholdOS = 24.8845;
int num = 1;
Serial.setTimeout(100);
pinMode(enA, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
ReadSerial();
switch (num) {
case 1:    //Read Serial should change value to 1 to start moveup
MoveUp();  //at end of moveup value changes to 2
case 2:
  TopDownBacklash(); //changes to 3 "Wait();"
case 3:
  WaitTop();
case 4:
  MoveDown();
case 5:
  BottomUpBacklash(); //num = 3 "Wait();"
case 6:
  WaitBottom();
void ReadSerial() {
sylvacRad = Serial.readString();
Serial.println(FloatRad, 4);
void MoveUp () {
if (FloatRad < Hthreshold) {
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
analogWrite(enA, 255);
num = 2;
void TopDownBacklash() {
if (FloatRad > HthresholdOS) {
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
analogWrite(enA, 100);
num = 3;
void MoveDown() {
if (FloatRad > Lthreshold) {
num = 5;
void BottomUpBacklash() {
if (FloatRad < LthresholdOS) {
num = 6;
void WaitTop() {
if (FloatRad > Hthreshold && FloatRad < HthresholdOS) {
analogWrite(enA, 180);
num = 4;
void WaitBottom() {
if (FloatRad < Lthreshold && FloatRad > LthresholdOS) {
num = 1;
Also is anyone having trouble posting code since the update? I have to add four space before each line of code to get it to post looking right, thanks everyone!
