Dear All,
New as Arduino user, I have a problem using a SSD1306 I2C display.
I wrote a sketch nicely working for a test bench. The source code is below.
I need now to add a display showing the number of cycles executed by the sketch.
If the “Display();” statement in line N° 62 is put under comments, everything works fine. If I uncomment
it, the sketch didn’t loop. Could someone help me ? Thanks.
Sketch :
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#if (SSD1306_LCDHEIGHT != 64)
#error(“Height incorrect, please fix Adafruit_SSD1306.h!”);
#endif
int durationZDown = 75;
int durationZUp = 45;
int durationXForward = 45; // 60
int durationXBackward = 45; // 60
int durationPause = 10;
int courseX = 10000; // max 5000
int courseZ = 4000; // max 6000
int seq = 0;
int Xposition = 0;
int Cycles = 0;
void setup() // Initialization
Serial.begin(19200);
display.begin(SSD1306_SWITCHCAPVCC, 0x3c); // initialize with the I2C addr 0x3D (for the 128x64)
// Clear the buffer.
display.clearDisplay();
display.display();
pinMode(2, OUTPUT); // Z axis direction
pinMode(3, OUTPUT); // Z axis steps
pinMode(4, OUTPUT); // X axis direction
pinMode(5, OUTPUT); // X axis steps
pinMode(6, INPUT); // X axis detection sample pipetting position
pinMode(7, INPUT); // X axis detection preparation rotor pipetting position
pinMode(8, INPUT); // Z axis detection top position
digitalWrite(2, HIGH); // Z axis direction
digitalWrite(3, HIGH); // Z axis steps
digitalWrite(4, LOW); // X axis direction
digitalWrite(5, LOW); // X axis steps
BeginOfTest();
RazV(); // Set Z arm on his top position
RazH(); // Set X arm on his backward position
delay(durationPause*50);
Cycles = 0;
Testing();
Cycles=Cycles + 1;
//Display();
void BeginOfTest()
// text display tests
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println("- ***** -");
display.setCursor(0,32);
display.setTextSize(1);
display.println(“The test will start”);
display.setCursor(0,40);
display.println(" soon");
display.setTextColor(BLACK, WHITE); // ‘inverted’ text
display.display();
delay(2000);
display.display();
void Display()
display.setCursor(30, 30);
display.println(Cycles);
display.display();
display.display();
void EndOfTest()
Cycles=0;
do
display.println(" Test");
display.setCursor(0,30);
display.println(“achieved !”);
display.display();
display.display();
while(Cycles=1);
void Testing()
// action : move X axis forward --------------------------------------------------------------------------
delayMicroseconds(durationXForward/4);
digitalWrite(5, HIGH);
if (digitalRead(4)== LOW)
Xposition = Xposition +1;
if (Xposition == 5800)
//delay(durationPause*100);
courseZ = 4400;
Pipetting();
courseZ = 4000;
Xposition = Xposition -1;
if (digitalRead(7)== 0)
digitalWrite(4, HIGH);
delay(durationPause);
//Emplacement pour la routine de pipettage
if (seq==0)
courseZ = 9200;
Pipetting();
seq=1;
courseZ = 4000;
if (digitalRead(8)== 0)
if (seq==1)
courseZ = 2000;
Pipetting();
seq=0;
courseZ = 4000;
void RazH() //
// action : move X axis backward ------------------------------------------------------------------------------------
do
delayMicroseconds(durationXBackward/4);
while (digitalRead(8) != 0);
void RazV()
// action : move Z axis upward --------------------------------------------------------------------------------------
do
digitalWrite(3, LOW);
delayMicroseconds(durationZUp/4);
while (digitalRead(6) != 0);
digitalWrite(2, LOW);
void Pipetting()
// action : move Z down, pump in or pump out, move Z up -------------------------------------------------------------
do
delayMicroseconds(durationZUp);
delayMicroseconds(durationZUp/2.5);
for (int i=0; i <= courseZ; i++)
delayMicroseconds(durationZDown);
delayMicroseconds(durationZDown/2.5);
do
//exit(0);
