Problem using Arduino Leonardo, midiUSB library and Ableton
Hello everyone ! :slight_smile:
I’ve a project with Arduino and Ableton since few weeks, I want to light on led strip with the fastLed library command by Midi message from Ableton.
I’m using the MidiUSB library but I doesn’t receive anything on the serial console. When I play or stop in Ableton I receive something but I can’t receive any note.
After many hours of reading and testing codes, I haven’t found any solution :’(
This is my code which is the basic code from MidiUSB.
#include <MIDIUSB.h>
const char* pitch_name(byte pitch) {
  static const char* names[] = {"C", "C#", "D", "D#", "E", "F", "F#", "G", "G#", "A", "A#", "B"};
  return names[pitch % 12];
int pitch_octave(byte pitch) {
  return (pitch / 12) - 1;
void noteOn(byte channel, byte pitch, byte velocity) {
  Serial.print("Note On: ");
  Serial.print(pitch_name(pitch));
  Serial.print(pitch_octave(pitch));
  Serial.print(", channel=");
  Serial.print(channel);
  Serial.print(", velocity=");
  Serial.println(velocity);
void noteOff(byte channel, byte pitch, byte velocity) {
  Serial.print("Note Off: ");
void controlChange(byte channel, byte control, byte value) {
  Serial.print("Control change: control=");
  Serial.print(control);
  Serial.print(", value=");
  Serial.print(value);
  Serial.println(channel);
  Serial.begin(192000);
  midiEventPacket_t rx = MidiUSB.read();
  switch (rx.header) {
    case 0:
      break; //No pending events
    case 0x9:
      noteOn(
        rx.byte1 & 0xF,  //channel
        rx.byte2,        //pitch
        rx.byte3         //velocity
    case 0x8:
      noteOff(
        rx.byte2,        //pitch
        rx.byte3         //velocity
    case 0xB:
      controlChange(
        rx.byte2,        //control
        rx.byte3         //value
    default:
      Serial.print("Unhandled MIDI message: ");
      Serial.print(rx.header, HEX);
      Serial.print("-");
      Serial.print(rx.byte1, HEX);
      Serial.print("-");
      Serial.print(rx.byte2, HEX);
      Serial.print("-");
      Serial.println(rx.byte3, HEX);
Any help would really be appreciated! Thanks a lot !
Edit : I've found and solved the problem, it's come from my Ableton and not Arduino, I'm sorry for bothered you.
Thanks for getting back with this information. Have a Karma point.
I did take a look at the code and couldn’t see much wrong with it other than you didn’t have a loop in the setup function that waited for the USB connection to become valid. That might delay it responding but only for the first second or so.
