Problem using delay in speedometer routine of REALDASH
I use a arduino Mega to send warning light signals via bluetooth to a tablet running the Realdash app.
Editing the sample file, i include a pin for speed sensor reading to update the speedometer, it happens that the code I entered has a delay of 300ms, it is slow for the other lights and is too fast for speedometer.
If i increase the delay, the displayed speed increase, if i decrease the delay, the displayed speed decrease.
The problem is that this delay slows the sending of other signals, which causes the direction lights to fail when times coincide.
And the number of speedometer change is too fast, I wanted to update the speed value every 1 second, but leave a maximum of 100ms of delay throughout the routine, as I do to eliminate this delay and measure the speed correctly and update its value every time 1 second using interruption code. Thanks.
 *  Name        : RealDash_CAN.ino
 *  Part of     : RealDash
 *  Author      : Jani Immonen
 *  Created     : 15.10.2017
 * Arduino example sketch of how to use RealDash CAN protocol.
 * This example code is free for any use.
 * www.realdash.net
unsigned int digitalPins = 0;
int analogPins[7] = {0};
unsigned int tanque = 0;
unsigned int tanque_mapeado = 0;
long rpmcount;
long velocidade;
  attachInterrupt(digitalPinToInterrupt(20), rpm_fun, CHANGE);
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  delay (200);
  rpm();
  rpm_fun();
  ReadDigitalStatuses();
  ReadAnalogStatuses();
  SendCANFramesToSerial();
void rpm()
  long count;
  cli();
  count = rpmcount;
  sei();
  delay (300);
  velocidade = int(rpmcount);
  rpmcount = 0;
void rpm_fun()
   rpmcount++;
void ReadDigitalStatuses()
  // read status of digital pins (1-13)
  digitalPins = 0;
  int bitposition = 0;
  for (int i=1; i<14; i++)
    if (digitalRead(i) == LOW) digitalPins |= (1 << bitposition);
    bitposition++;
void ReadAnalogStatuses()
  // read analog pins (0-7)
  tanque = analogRead (0);
  tanque_mapeado = map(tanque,14,96,1023,0);
  for (int i=0; i<7; i++)
    analogPins[i] = analogRead(i);
void SendCANFramesToSerial()
  byte buf[8];
  // build 2nd CAN frame, Arduino digital pins and 2 analog values
  memcpy(buf, &digitalPins, 2);
  memcpy(buf + 2, &tanque_mapeado, 2);
  memcpy(buf + 4, &velocidade, 2);
  memcpy(buf + 6, &analogPins[2], 2);
  // write 2nd CAN frame to serial
  SendCANFrameToSerial(3201, buf);
  // build 3rd CAN frame, rest of Arduino analog values
  memcpy(buf, &analogPins[3], 2);
  memcpy(buf + 2, &analogPins[4], 2);
  memcpy(buf + 4, &analogPins[5], 2);
  memcpy(buf + 6, &analogPins[6], 2);
  // write 3rd CAN frame to serial
  SendCANFrameToSerial(3202, buf);
void SendCANFrameToSerial(unsigned long canFrameId, const byte* frameData)
  // the 4 byte identifier at the beginning of each CAN frame
  // this is required for RealDash to 'catch-up' on ongoing stream of CAN frames
  const unsigned long serialBlockTag = 0x11223344;
  Serial.write((const byte*)&serialBlockTag, 4);
  // the CAN frame id number
  Serial.write((const byte*)&canFrameId, 4);
  // CAN frame payload
  Serial.write(frameData, 8);
Replace the blocking delay() with non-blocking millis() timeing.
Non-blocking timing tutorials:
Several things at a time.
Beginner's guide to millis().
Blink without delay().
