Problem using Ethernet shield
Have found in the forum an example of a webpage on an Arduino displaying four
pushbuttons , that I have modified a little , and it works fine . But then I wanted
to include a potentiometer reading in the scetch and had it´s value displayed (ReadValue)
on that web-page , but not succeeded ...have tried to find a solution among
other examples ... but no luck ...
here is the code :
/*  Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
  Potentiometer to A0
#include <EtherCard.h>
// Ethernet Part declaration
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
#define BUFFER_SIZE 800
BufferFiller bfill;
byte Ethernet::buffer[BUFFER_SIZE];
static byte myip[] = {192,168,0,2};
// Ethernet Part ends here
// Diodepins definition
const int ledPin1 = 3;
const int ledPin2 = 4;
const int ledPin3 = 5;
//Volt meter start
//Analog volt read pin
const int voltPin = 0;
float Readvalue;
void setup () {
 /*    sök efter ip-adress till Arduinon    */
   Serial.println("\n[Starting the Arduino Server]");
  Serial.print("MAC: ");
  for (byte i = 0; i < 6; ++i) {
    Serial.print(mymac[i], HEX);
    if (i < 5)
      Serial.print(':');
  if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
    Serial.println( "Failed to access Ethernet controller");
  Serial.println("Setting up DHCP (this can take a while...)");
  if (!ether.dhcpSetup())
    Serial.println( "DHCP failed");
  ether.printIp("IP: ", ether.myip);
  ether.printIp("Netmask: ", ether.mymask);
  ether.printIp("GW IP: ", ether.gwip);
  ether.printIp("DNS IP: ", ether.dnsip);
  ether.printIp("Surf to this IP to view the Arduino Server: ", ether.myip);
 myip ==ether.myip;
 /*    initierad ...*/
//Ethernet Debugging
ether.begin(sizeof Ethernet::buffer, mymac);
ether.staticSetup(myip);
//Ethernet Debugging Ends Here
// Turn off all diodes
  pinMode(ledPin1, OUTPUT);
  digitalWrite(ledPin1, LOW);
  pinMode(ledPin2, OUTPUT);
  digitalWrite(ledPin3, LOW);
  pinMode(ledPin3, OUTPUT);
void homepage(){
      bfill.emit_p(PSTR(
"<!DOCTYPE html><html><title>Ethernet Controller</title>"
"<body><div id='content' style='background-color:lightgreen;width:1100px;height:900px;'><hr><h1><p><center><font size='28'>
Kalles Arduino-website
test
"</p><hr>
<table bgcolor='#58D3F7' border='1'><tr><th colspan='4' >Choose diode :</th></tr>"
"<tr><td><INPUT Type='BUTTON' VALUE='Red ' ONCLICK='window.location.href=\"/?cmd=Red\"'></td><td>"
"<INPUT Type='BUTTON' VALUE='Yellow' ONCLICK='window.location.href=\"/?cmd=Yellow\"'></td>"
"<td><INPUT Type='BUTTON' VALUE='Green' ONCLICK='window.location.href=\"/?cmd=Green\"'></td>"
"<td><INPUT Type='BUTTON' VALUE='Off' ONCLICK='window.location.href=\"/?cmd=Off\"'></td></tr>"
"</table>
<hr>xxx</font>
<hr></div></body></html>"
void http_Unauthorized(){
      bfill.emit_p(PSTR("HTTP/1.0 401 Unauthorized\r\n"
    "Content-Type: text/html\r\n\r\n"
    "<h1>401 Unauthorized</h1>"
  //checking for requesting client
  word len = ether.packetReceive();
  word pos = ether.packetLoop(len);
  if(pos) {
    bfill = ether.tcpOffset();
    //storing buffer on data variable
    char *data = (char *) Ethernet::buffer + pos;
    if (strncmp("GET /", data, 5) != 0) {
            // Unsupported HTTP request
            // 304 or 501 response would be more appropriate
             http_Unauthorized();
    else {
        data += 5;
            if (data[0] == ' ') {
                // Return home page
                homepage();
            else if (strncmp("?cmd=Red ", data, 8) == 0) {
                homepage();
               digitalWrite(ledPin1, HIGH);      // Red diode on
                digitalWrite(ledPin2, LOW);
            else if (strncmp("?cmd=Yellow ", data, 11) == 0) {
              homepage();
                  digitalWrite(ledPin2, HIGH);    // Yellow diode on
            else if (strncmp("?cmd=Green ", data, 10) == 0) {
                homepage();
                 digitalWrite(ledPin3, HIGH);     // Green diode on
            else if (strncmp("?cmd=Off ", data, 8) == 0) {
                homepage();
                 digitalWrite(ledPin1, LOW);       // All off
            else {
                // Page not found
        Readvalue=VoltageMeasure();
    ether.httpServerReply(bfill.position());
    len ==0;
float VoltageMeasure()
  float voltage;
  //volt meter start
//Obtain RAW voltage data
voltage = analogRead(voltPin);
//Convert to actual voltage (0 - 5 Vdc)
voltage = (voltage / 1024) * 5.0;
return voltage;
Webpage_med_inmatning_av_data.ino (4.76 KB)
If you want a value to appear on the HTML page you should add it to the HTML text in homepage().
One way to get the arduino analog pin inputs into a web page using frames.
// zoomkat's meta refresh data frame test page 5/25/13
// use http://192.168.1.102:84 in your brouser for main page
// http://192.168.1.102:84/data static data page
// http://192.168.1.102:84/datastart meta refresh data page
// for use with W5100 based ethernet shields
// set the refresh rate to 0 for fastest update
// use STOP for single data updates
#include <SPI.h>
#include <Ethernet.h>
const int analogInPin0 = A0;
const int analogInPin1 = A1;
const int analogInPin2 = A2;
const int analogInPin3 = A3;
const int analogInPin4 = A4;
const int analogInPin5 = A5;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // arduino ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
unsigned long int x=0; //set refresh counter to 0
String readString;
void setup(){
    // disable SD SPI if memory card in the uSD slot
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  Serial.println("meta refresh data frame test 5/25/13"); // so I can keep track of what is loaded
void loop(){
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
         if (readString.length() < 100) {
          readString += c;
        //check if HTTP request has ended
        if (c == '\n') {
          //check get atring received
          Serial.println(readString);
          //output HTML data header
          client.println("Content-Type: text/html");
          client.println();
          //generate data page
          if(readString.indexOf("data") >0) {  //checks for "data" page
            x=x+1; //page upload counter
            client.print("<HTML><HEAD>");
            //meta-refresh page every 1 seconds if "datastart" page
            if(readString.indexOf("datastart") >0) client.print("<meta http-equiv='refresh' content='1'>");
            //meta-refresh 0 for fast data
            if(readString.indexOf("datafast") >0) client.print("<meta http-equiv='refresh' content='0'>");
            client.print("<title>Zoomkat's meta-refresh test</title></head><BODY>
            client.print("page refresh number: ");
            client.print(x); //current refresh count
            client.print("
              //output the value of each analog input pin
            client.print("analog input0 is: ");
            client.print(analogRead(analogInPin0));
            client.print("
analog input1 is: ");
            client.print(analogRead(analogInPin1));
            client.print("
analog input2 is: ");
            client.print(analogRead(analogInPin2));
            client.print("
analog input3 is: ");
            client.print(analogRead(analogInPin3));
            client.print("
analog input4 is: ");
            client.print(analogRead(analogInPin4));
            client.print("
analog input5 is: ");
            client.print(analogRead(analogInPin5));
            client.println("
</BODY></HTML>");
          //generate main page with iframe
            client.print("<HTML><HEAD><TITLE>Zoomkat's frame refresh test</TITLE></HEAD>");
            client.print("Zoomkat's Arduino frame meta refresh test 5/25/13");
            client.print("
Arduino analog input data frame:
            client.print("&nbsp;&nbsp;<a href='http://192.168.1.102:84/datastart' target='DataBox' title=''yy''>META-REFRESH</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='http://192.168.1.102:84/data' target='DataBox' title=''xx''>SINGLE-STOP</a>");
            client.print("&nbsp;&nbsp;&nbsp;&nbsp;<a href='http://192.168.1.102:84/datafast' target='DataBox' title=''zz''>FAST-DATA</a>
            client.print("<iframe src='http://192.168.1.102:84/data' width='350' height='250' name='DataBox'>");
            client.print("</iframe>
</HTML>");
          delay(1);
          //stopping client
          client.stop();
          //clearing string for next read
          readString="";
OK thanks ... but for the first answer : Yes I have tried to include in the Homepage() HTML...
but never succeeded..
As for the second answer , it works for an W5100 shield , but I forgot to tell I have a compatible ...
KalleL:
I guess it is time to try it again. If you show your code and report your results we might be able to guide you in the correct direction.
