Problem using HC-SR04 as ON/OFF----Problema usando HC-SR04 como interruptor
-------------------------------------------------------ENGLISH--------------------------------------------------
Hi, I'm new into arduino, I only created a few proyects. I'm having probles with using the HC-SR04 as an ON/OFF module and also with the position of the servo. My objective is to be able to, with one servo and one HC-SR04 open and close a door and let the servo holding the position.
Right now I made this code but the servo returns to the original poition and i want it to stay until i pass the hand again.
-------------------------------------------------------SPANISH--------------------------------------------------
Muy buenas, soy relativamente nuevo con el arduino, estoy teniendo problemas a la hora de usar el HC-SR04 como un interruptor.Es deci, mi objetivo es pasar la mano por encima del sensor y que abra una puerta, y si volvemos a pasar la mano, que esta se cierre. Por ahora solo he conseguido que al pasar la mano el servo se mueva hasta los 90 grados y una vez quito la mano, el servo vuelve a su posicion. No consigo dar con la forma para que este mantenga su posicion.
Gracias de antemano.
-----------------------------------------------------CODE/CODIGO----------------------------------------------
#include <Servo.h>
const int trigPin = 6;//Setup the variables for the HC-SR04
const int echoPin = 5;
Servo myservo;
// create servo object to control a servo
// variable to store the servo position
int pos = 0;
int pos3 = 90;
// initialize serial communication:
// attaches the servo on pin 9 to the servo object
myservo.attach(9);
long duration, inches, cm;
// The sensor is triggered by a HIGH pulse of 10 or
// more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the signal from the sensor: a HIGH pulse whose
// duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
//Tell the Arduino to print the measurement in the serial console
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
//----------------comenzamos con las posiciones del motor---------------
if (cm >= 30 ) {myservo.write(pos); //posiciones segun distancia
else if (cm >= 0 && cm < 30) {myservo.write(pos3);//distintas posiciones del servo
delay(50);
long microsecondsToInches(long microseconds)
return microseconds / 74 / 2;
//Converts the Microseconds Reading to Centimeters
long microsecondsToCentimeters(long microseconds)
return microseconds / 29 / 2;
-----------------------------------------------------END OF CODE-----------------------------------------
Thanks for your help.
What "original position"?
What "pass hand again"?
Please explain your project in more detail.
Okay, I’m sorry because of the explanation.
The objective is: when you pass the hand in front os the sensor, it has to move the servo till 90 degrees and hold the position of 90 degrees.(The initial position is of 0 degrees.)
And if we pass the hand again in front of the sensor, I want to return to 0 and hold the 0 degrees untill I pass the hand again. It can be used in a door.
Right now my code moves the servo but it doesnt hold the position, it returns when I move away the hand from the front of the servo.
I’m using an arduino mega 2560, a microservo and a HC SR04.
Thanks
Holaaaaaaaaaaaaaa
estas en el foro en Español por si no te diste cuenta.
Si algo no debes hacer nunca es escribir algo en inglés y luego en otro idioma. Los ofende terriblemente y enseguida te mandan al foro del idioma.
Pero peor aún es que tu código tenga comentarios en español
Ahora no se te ocurra crear un nuevo hilo con este tema.
Intentemos solucionar este. para lo cual te pido leas el privado que te envié ayer creo.
Edita tu hilo usando etiquetas.
