Problem using L293D with a 3 - 6 V DC motor
I´m trying to fix a trash bin with an arduino sketch (ultrassonic sensor, L293D, arduino pro mini, 7805, 9v battery, DC motor of trash bin).
When not connected to a PC, not work.
When connected to a PC works a few times. After some times works only for open a trash bin and never closes it.
I really appreciate some advice.
#include <Narcoleptic.h>
#include <Ultrasonic.h>
// definicao das portas usadas para o sensor ultrassonico
#define echoPin 6
#define triggerPin 7
//definicao das portas usadas para o L293D - po nte para acionar motor
#define motorPin1 3
#define motorPin2 4
#define motorEnable 9
#define ledopen 12
#define ledclose 13
Ultrasonic ultrasonic(echoPin,triggerPin);
pinMode(triggerPin, OUTPUT);
pinMode(echoPin, INPUT);
// “programa portas do L293D”
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorEnable, OUTPUT);
// pinos dos leds
pinMode(ledopen, OUTPUT);
pinMode(ledclose, OUTPUT);
digitalWrite(triggerPin, LOW);
delayMicroseconds(2);
digitalWrite(triggerPin, HIGH);
delayMicroseconds(10);
long duration = pulseIn(echoPin, HIGH);
int cm = microsecondsToCentimeters(duration);
if(cm <= 50 && cm >=5)
abreTampa();
void abreTampa()
Serial.println(“abrindo tampa”);
digitalWrite(motorEnable, HIGH);
digitalWrite(motorPin1, 1); //
digitalWrite(motorPin2, 0); //
Serial.println("espera 5 segundos ");
Narcoleptic.delay(5000);
digitalWrite(motorPin1, 0); // para o motor
Serial.println(“fechando tampa”);
digitalWrite(motorPin2, 1);
Serial.println("…end … ");
void fechaTampa()
digitalWrite(motorPin1, LOW);
digitalWrite(motorPin2, HIGH);
Narcoleptic.delay(3000);
digitalWrite(motorEnable, LOW);
float microsecondsToCentimeters(long microseconds)
float seconds = (float) microseconds / 1000000.0;
float distance = seconds * 340;
distance = distance / 2;
distance = distance * 100;
return distance;
9V battery - no use at all for motors.
