Hi guys,
I am using a DHT11 sensor with an LED to display data. I tried my code on an Arduino Uno and it worked and compiled perfectly.
But I have to use WiFi to send my data so I decided to use a Genuino MKR 1000
When I tried to compile to code I received an error message and I am not able to solve it,
#include <dht.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
dht DHT;
#define DHT11_PIN 7
void setup(){
lcd.begin(16, 2);
//int chk = DHT.read11(DHT11_PIN);
lcd.setCursor(0,0);
// lcd.print("Temp: ");
//lcd.print(DHT.temperature);
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Humidity: ");
// lcd.print(DHT.humidity);
lcd.print("%");
delay(1500);
Compilation error:
In file included from C:\Users\nicol\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.20\cores\arduino/delay.h:23:0,
from C:\Users\nicol\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.20\cores\arduino/Arduino.h:81,
from C:\Users\nicol\Documents\Arduino\libraries\DHTLib\dht.h:18,
from C:\Users\nicol\Documents\Arduino\libraries\DHTLib\dht.cpp:30:
C:\Users\nicol\Documents\Arduino\libraries\DHTLib\dht.cpp: In member function 'int dht::_readSensor(uint8_t, uint8_t)':
C:\Users\nicol\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.20\variants\mkr1000/variant.h:47:78: error: invalid conversion from 'PortGroup*' to 'uint8_t {aka unsigned char}' [-fpermissive]
#define digitalPinToPort(P) (&(PORT->Group[g_APinDescription[P].ulPort]))
C:\Users\nicol\Documents\Arduino\libraries\DHTLib\dht.cpp:115:17: note: in expansion of macro 'digitalPinToPort'
uint8_t port = digitalPinToPort(pin);
C:\Users\nicol\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.20\variants\mkr1000/variant.h:51:41: error: base operand of '->' is not a pointer
#define portInputRegister(port) (&(port->IN.reg))
C:\Users\nicol\Documents\Arduino\libraries\DHTLib\dht.cpp:116:29: note: in expansion of macro 'portInputRegister'
volatile uint8_t *PIR = portInputRegister(port);
I hope you can help me and this is the right sub forum
