Hi guys.
I have a problem changing my ESP8266 program from Arduino UNO to Arduino Mega2560.
When using Arduino UNO, im using espduino and SoftwareSerial library (with help of prolic usb to serial port). the code goes like this :
* \file
* ESP8266 MQTT Bridge example
* \author
* Tuan PM <tuanpm@live.com>
#include <SoftwareSerial.h>
#include <espduino.h>
#include <mqtt.h>
SoftwareSerial debugPort(2, 3); // RX, TX
ESP esp(&Serial, &debugPort, 4);
MQTT mqtt(&esp);
boolean wifiConnected = false;
void wifiCb(void* response)
uint32_t status;
RESPONSE res(response);
if(res.getArgc() == 1) {
res.popArgs((uint8_t*)&status, 4);
if(status == STATION_GOT_IP) {
debugPort.println("WIFI CONNECTED");
mqtt.connect("yourserver.com", 1883, false);
wifiConnected = true;
//or mqtt.connect("host", 1883); /*without security ssl*/
mqtt.disconnect();
void mqttConnected(void* response)
debugPort.println("Connected");
mqtt.subscribe("/topic/0"); //or mqtt.subscribe("topic"); /*with qos = 0*/
mqtt.subscribe("/topic/1");
mqtt.subscribe("/topic/2");
mqtt.publish("/topic/0", "data0");
void mqttDisconnected(void* response)
void mqttData(void* response)
debugPort.print("Received: topic=");
String topic = res.popString();
debugPort.println(topic);
debugPort.print("data=");
String data = res.popString();
debugPort.println(data);
void mqttPublished(void* response)
Serial.begin(19200);
debugPort.begin(19200);
esp.enable();
esp.reset();
while(!esp.ready());
debugPort.println("ARDUINO: setup mqtt client");
if(!mqtt.begin("DVES_duino", "admin", "Isb_C4OGD4c3", 120, 1)) {
debugPort.println("ARDUINO: fail to setup mqtt");
while(1);
debugPort.println("ARDUINO: setup mqtt lwt");
mqtt.lwt("/lwt", "offline", 0, 0); //or mqtt.lwt("/lwt", "offline");
/*setup mqtt events */
mqtt.connectedCb.attach(&mqttConnected);
mqtt.disconnectedCb.attach(&mqttDisconnected);
mqtt.publishedCb.attach(&mqttPublished);
mqtt.dataCb.attach(&mqttData);
/*setup wifi*/
debugPort.println("ARDUINO: setup wifi");
esp.wifiCb.attach(&wifiCb);
esp.wifiConnect("DVES_HOME","wifipassword");
debugPort.println("ARDUINO: system started");
esp.process();
if(wifiConnected) {
Now Im going to change it to Arduino Mega 2560,
can anybody help what code to be change when using MultiSerialPort on Arduino Mega2560?
Think we dont need the SoftwareSerial library anymore, but how to use espduino.h on Arduino Mega2560 if not using SoftwareSerial and prolific USB to serial port helps?
Thank you.
