C:\arduino-1.5.2\hardware\tools\avr\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=152 -IC:\arduino-1.5.2\hardware\arduino\avr\cores\arduino -IC:\arduino-1.5.2\hardware\arduino\avr\variants\standard -IC:\Users\JAN\Documents\libraries\DallasTemperature C:\Users\JAN\AppData\Local\Temp\build1337970322373753565.tmp\DS18x20_Temperature.cpp -o C:\Users\JAN\AppData\Local\Temp\build1337970322373753565.tmp\DS18x20_Temperature.cpp.o
C:\arduino-1.5.2\hardware\tools\avr\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=152 -IC:\arduino-1.5.2\hardware\arduino\avr\cores\arduino -IC:\arduino-1.5.2\hardware\arduino\avr\variants\standard -IC:\Users\JAN\Documents\libraries\DallasTemperature -IC:\Users\JAN\Documents\libraries\DallasTemperature\utility C:\Users\JAN\Documents\libraries\DallasTemperature\BSeries.cpp -o C:\Users\JAN\AppData\Local\Temp\build1337970322373753565.tmp\DallasTemperature\BSeries.cpp.o
C:\Users\JAN\Documents\libraries\DallasTemperature\BSeries.cpp:32:24: error: WConstants.h: No such file or directory
C:\Users\JAN\Documents\libraries\DallasTemperature\BSeries.cpp: In member function 'virtual float BSeries::getTemperature(NewOneWire*)':
C:\Users\JAN\Documents\libraries\DallasTemperature\BSeries.cpp:43: error: 'byte' was not declared in this scope
C:\Users\JAN\Documents\libraries\DallasTemperature\BSeries.cpp:43: error: expected ;' before 'lowByte' C:\Users\JAN\Documents\libraries\DallasTemperature\BSeries.cpp:44: error: expected ;' before 'highByte'
C:\Users\JAN\Documents\libraries\DallasTemperature\BSeries.cpp:48: error: 'highByte' was not declared in this scope
C:\Users\JAN\Documents\libraries\DallasTemperature\BSeries.cpp:48: error: 'lowByte' was not declared in this scope
What confuses me here is the reference to DallasTemperature library and Bseries.cpp which as far as I can see is not part of my program. Never referenced in the sample code or in the OneWire code. I would also expect that a sample code would work directly.
The code in the example that can be choosen from inside Arduino IDE
File/Examples/OneWire/DS18x20_Temperature
which is
#include <OneWire.h>
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
OneWire ds(10); // on pin 10 (a 4.7K resistor is necessary)
void setup(void) {
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
PaulS:
What Arduino are you compiling for? Unless you have a Due or a Micro, you don't need to be using 1.5.x.
For a UNO, on 1.0.5, I got just this one "error" message:
Binary sketch size: 6,592 bytes (of a 32,256 byte maximum)
And I also get that result on PC at my office. I do notice in this case there are no reference to including this
but why trying to include DallasTemperature on my computers at home ? Nowhere in the code is that stated.
