Problem using Pro Micro as ISP to Attiny85
Hello
Using Pro Micro board as ISP to ATtiny85.
i have an issue that i cannot burn the bootloader with the programmer "Arduino as ISP"
When i do it with the programmer "Arduino Leo/Micro as ISP (ATmega32U4)" it does burn it succesfully.
but when i then upload the blink sketch (it does that succesfully) nothing happends, no blinking of the LED. The led turns off when uploading the sketch, but then turns on and keeps on.
( i used as guide to setup: https://www.instructables.com/Mini-Breadboard-Pro-Micro-ISP-for-DIP8-ATTiny-Seri/
maybe anyone an idea what iam missing?
I am a beginner in this world.
Maybe a bypass cap for the tiny? The Instructables article does not show one, no surprise there.
It should be a 0.1uF ceramic cap, connected across the Vcc & ground pins of the tiny, as close as you can get it.
Thanks for the reply, unfortunately i do not have a 0.1 uF , only a 10uF.
but i also see that never mentioned anywhere in the schematics of putting it in
You will find 0.1uF capacitors are not expensive.
What schematic are you referring to? One from the attiny85 data sheet?
it turns out the board was faulty, i have bought a new UNO and now it works fine.
