Problem using 'sendPronto' in IRremote.h
First of all, I'm using GitHub - Arduino-IRremote/Arduino-IRremote: Infrared remote library for Arduino: send and receive infrared signals with multiple protocols , not the built in IRremote libary.
I'm trying to use the sendPronto function in IRremote.h but I get this error and I don't know why:
C:\Users\ALEXAN~1\AppData\Local\Temp\ccbmPhPT.ltrans0.ltrans.o: In function `loop':
C:\Users\Alexander\Documents\Arduino\test/test.ino:107: undefined reference to `IRsend::sendPronto(char*, bool, bool)'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Nano.
Here is my code:
//Ir libaries
#include <IRremoteInt.h>
#include <IRremote.h>
#include <boarddefs.h>
//Is useful
#include <Streaming.h>
//Some numbers used to keep track of what the user wants to send
#define TYPE_NEC 0
#define TYPE_LG 1
#define TYPE_PRONTO 2
#define TYPE_ERROR 3
String inputBuffer; //Store recieved text
char buf; //Store 1 recieved character
char inputStr[30]; //Convert C sting to char. Also stores the code that the user wants to send.
char outputType [7]; //Another string?!
unsigned long wait; //Currently unused
byte type = TYPE_ERROR; //The code type to send
IRsend IR; //IR object
	Serial.begin(115200); //Serial
  /* add setup code here */
	if (Serial.available())
		buf = Serial.read();
		if (buf == '>')
			inputBuffer.toCharArray(inputStr, 30);
			Serial << "inputBuffer = " << inputBuffer << endl;
			Serial << "inputStr = " << inputStr << endl;
			inputBuffer = "";
			if (sscanf(inputStr, "%s %lu", &outputType, &wait) == 2)
				Serial << "outputType = " << outputType << " wait = " << wait << endl;
				if (!strcmp(outputType, "NEC"))
					Serial << "Preparing to send a NEC IR code" << endl;
					type = TYPE_NEC;
				else if (!strcmp(outputType, "LG"))
					Serial << "Preparing to send a LG IR code" << endl;
					type = TYPE_LG;
				else if (!strcmp(outputType, "PRONTO"))
					Serial << "Preparing to send a PRONTO HEX code" << endl;
					type = TYPE_PRONTO;
				Serial << "Error." << endl;
				return;
		else if (buf == ';')
			unsigned long HEXCode = 0;
			inputBuffer = "";
			if (type == TYPE_ERROR)
				Serial << "Error in type string, aborting" << endl;
				return;
			else if (type == TYPE_NEC)
				if (sscanf(inputStr, "%lx", &HEXCode))
					IR.sendNEC(HEXCode, 32);
					Serial << "Sent " << HEXCode << " in NEC format." << endl;
					Serial << "Error: " << inputStr << " not valid." << endl;
			else if (type == TYPE_LG)
					IR.sendLG(HEXCode, 32);
					Serial << "Sent " << HEXCode << " in LG format." << endl;
			else if (type == TYPE_PRONTO)
				IR.sendPronto(inputStr, false, false);
				Serial << "Sent a code that is too long to fit here in PRONTO format." << endl;
				return;
		else //Build the string buffer
			inputBuffer += buf;
  /* add main program code here */
Does the library have an example of using the sendPronto() function ?
No, it doesn't, probably because of this problem.
I don't know of any alternative library, so I'm not sure what to do...
How do you KNOW that? Without enabling verbose mode, you don't know which library you are using, unless you deleted the version that ships with the IDE.
