So im creating a program with two separate ultrasonic sensors, each is supposed to make a separate LED blink faster and faster the closer an object comes. My problem lies within the loop function. Due to the loop running sequentially (At least I think this is the problem) the LED's are blinking in accordance to the furthest object on one of the ultrasonic sensors. Im not sure how to fix this. I have my entire code listed below. This is probably something obvious Im missing - excuse my noob-ness
//#include "DHT.h";
#define DHTTYPE DHT22 // DHT Type is DHT 22 (AM2302)
#define DHTPIN 7 // DHT-22 Output Pin connection
#define trigPin 5
#define echoPin 6
#define beepPin 12
#define trigPin2 8
#define echoPin2 9
#define beepPin2 10
#define scalingfactor 10
int hum = 25; // Stores humidity value in percent
int temp = 25; // Stores temperature value in Celcius
float soundsp; // Stores calculated speed of sound in M/S
float soundum; // Stores calculated speed of sound in cm/ms
//DHT dht(DHTPIN, DHTTYPE); // Initialize DHT sensor for normal 16mhz Arduino
int centi = 0;
int centi2 = 0;
unsigned long duration = 0;
unsigned long duration2 = 0;
unsigned long maxtime2 = 2000;
unsigned long maxtime = 2000;
unsigned long i = 1;
unsigned long y = 1;
unsigned long time2 = 0;
unsigned long time1 = 0;
unsigned long time3 = 0;
unsigned long time4 = 0;
Serial.begin (9600);
//dht.begin();
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(beepPin, OUTPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
pinMode(beepPin2, OUTPUT);
void temps(){
hum = dht.readHumidity(); // Get Humidity value
temp= dht.readTemperature(); // Get Temperature value
void calculate(){
// Calculate the Speed of Sound in M/S
soundsp = 331.4 + (0.606 * temp) + (0.0124 * hum);
// Convert to cm/us
soundum = soundsp / 10000;
void logdistance() {
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
centi = (duration* soundum)/2;
maxtime = scalingfactor * centi;
void delayandcheckdistance() {
i = 1;
while (1) {
if (i % 60 == 0) {
logdistance();
delay(1);
++i;
if (i >= maxtime) {
void beep() {
digitalWrite(beepPin, HIGH);
delay(60);
logdistance();
if (time2 - time1 < 30) {
delay(60 - (time2 - time1));
digitalWrite(beepPin, LOW);
void logdistance2() {
digitalWrite(trigPin2, HIGH);
digitalWrite(trigPin2, LOW);
duration2 = pulseIn(echoPin2, HIGH);
centi2 = (duration2* soundum)/2;
maxtime2 = scalingfactor * centi2;
void delayandcheckdistance2() {
y = 1;
while (1) {
if (y % 60 == 0) {
logdistance2();
delay(1);
++y;
if (y >= maxtime2) {
void beep2() {
digitalWrite(beepPin2, HIGH);
delay(60);
logdistance2();
if (time4 - time3 < 30) {
delay(60 - (time4 - time3));
digitalWrite(beepPin2, LOW);
beep();
delayandcheckdistance();
beep2();
delayandcheckdistance2();
calculate();
//print results
Serial.print("c. ");
Serial.print(centi);
Serial.print(" ");
Serial.print("||");
Serial.print(" ");
Serial.print(" ");
Serial.print(centi2);
Serial.println(" ");
Serial.print (" ");
