problem using Software Serial
hello ,
im having a problem using the software serial library.
basically, i want to send an analog value from one arduino board to another(both are uno)
circuit: http://imageshack.us/photo/my-images/10/21sz.jpg/
code for tx board:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12,13); // RX, TX
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  pinMode(0,INPUT); // pot analog value.
  pinMode(12,INPUT);//rx
  pinMode(13,OUTPUT); //tx
  Serial.write(analogRead(0));
  if(Serial.available()>0)
    mySerial.write(Serial.read());
code for rx board:
 mySerial.listen();
  if (mySerial.available()>0)
    if(mySerial.read()<400)
      //do something
    else if(mySerial.read()>900)
      //do something else
any idea what went wrong?
thanks.
The receiving arduino receives the character representation, not the numeric value
you must make a parser that builds up the number one digit at a time.
i dont think thats the problem, because even if it is, the data which is being recieved is corrupted; it shows -1 all the time!!
-1 means that there are no characters received,
Have you connected the TX of the sender to the receiver RX ?
Furthermore the line if(mySerial.read()<400) is always true
as serialRead() returns a int representing a char which is in the range 0…255 (and -1 if there is none)
int val = 0;
  bool ready = false;
  mySerial.listen();
    int c = mySerial.Read();
    switch(c)
      case '0'..'9': val *= 10 + c - '0'; break;  // add up individual chars to a numeric value
      default: ready = true;
    if (ready)
      if (val < 400)
        //do something
      else if (val > 900)
        //do something else
        //do something completely different
      val = 0; // reset;
thanks man! i manipulated your code a little and got mine to function properly!
you were right, if(mySerial.read()<400) is always true statement…
i used your approach of storing the char, switch/case it and then setting the boolean value for the ‘if’ statements…
Maybe post your working code for future reference for people who find this thread interesting?
since i wanted to compare the analog value, i did the comparison on the TX board, and sent a char over mySerial(‘f’ for false or ‘t’ for true) to the RX board, there on the RX i stored that char, then used switch\case to set a boolean flag for the ‘if’ statements…
it worked fine!
tx:
if(value<450)
    mySerial.write('f');
  if(value >900)
    mySerial.write('t');
rx:
char RXdata; boolean flag=false;
  mySerial.listen();
    RXdata = mySerial.read();
    switch(RXdata)
      case 't':
                flag=true;
      case 'f':
                //flag = false;
  if(flag)
  {// do something}
  else{//do something else}
