I am trying to use an AtTiny85 to communicate over Bluetooth. I use the code shown below with a voltage divider to reduce the voltage on pin 0 to an acceptable level for the HC-05. I get information transmitted but it is junk. Has anyone got an idea on this? Is there more hardware I need to look at? I have successfully done this with a Pro Mini using the normal serial communication but I need the smaller size of the AtTiny if possible.
Has anyone got an example of receiving and sending data using serially over Bluetooth? As usual the internet has provided more questions than answers.
#include <SoftwareSerial.h>
// Definitions
#define rxPin 1
#define txPin 0
SoftwareSerial mySerial(rxPin, txPin);
int sensorPin = 7; //ACTUALLY PIN LABELED AS "2" on the HLT tutorial
int sensorVal = -1;
boolean switchFans = 0;
// the setup routine runs once when you press reset:
pinMode(sensorPin, INPUT);
mySerial.begin(9600);
// the loop routine runs over and over asensorpingain forever:
sensorVal = analogRead(sensorPin);
mySerial.print("Input Val: " + sensorVal);
