Hello everybody
I'm having a problem that I can't figure out why.
I have this sketch here for ESP32 that I connect to the network with a static IP and call an NTPC library (GitHub - arduino-libraries/NTPClient: Connect to a NTP server) to get the time and it works very well:
// Load Wi-Fi library
#include <WiFi.h>
#include <ESP32Time.h>
#include <NTPClient.h>
#include <Timestamps.h>
// Replace with your network credentials
const char* ssid = "WIFI_T";
const char* password = "redacted";
// Set web server port number to 80
WiFiServer server(80);
// Variable to store the HTTP request
String header;
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 184);
// Set your Gateway IP address
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
IPAddress primaryDNS(8, 8, 8, 8); //optional
IPAddress secondaryDNS(8, 8, 4, 4); //optional
WiFiClient wifiClient;
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
ESP32Time rtc;
// Configures static IP address
if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
Serial.println("STA Failed to configure");
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local IP address and start web server
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
if (WiFi.status() == WL_CONNECTED) {
Serial.println("Conectado");
NTPCIniciar();
Serial.println("Define DATA");
defineData();
server.begin();
void loop(){
void NTPCIniciar()
//INICIALIZA O NTPC CLIENT PARA PEGAR DATA E HORA
timeClient.begin();
// Set offset time in seconds to adjust for your timezone, for example:
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
timeClient.setTimeOffset(-10800 /*CONFIGURADO PARA O FUSO HORÁRIO NO BRASIL*/);
void defineData() {
char ano2[5];
char mes2[3];
char dia2[3];
char hora2[3];
char minuto2[3];
char segundo2[3];
char dataHora2[21];
int anoInt2;
int mesInt2;
int diaInt2;
int horaInt2;
int minInt2;
int segInt2;
String formattedDate;
String dayStamp;
String timeStamp;
if (!timeClient.update()) {
Serial.println("Update");
timeClient.forceUpdate();
// The formattedDate comes with the following format:
// 2018-05-28T16:00:13Z
// We need to extract date and time
Serial.println("TIMESTAMP");
unsigned long timeStamp2 = timeClient.getEpochTime();
Serial.println(timeStamp2);
formattedDate = timeClient.getFormattedDate();
Serial.println(formattedDate);
// Extract date
int splitT = formattedDate.indexOf("T");
dayStamp = formattedDate.substring(0, splitT);
Serial.println("DATE: ");
Serial.println(dayStamp);
// Extract time
timeStamp = formattedDate.substring(splitT + 1, formattedDate.length() - 1);
Serial.println("HOUR: ");
Serial.println(timeStamp);
formattedDate.toCharArray(dataHora2, sizeof(dataHora2));
for (int i = 0; i < 4; i++)
ano2[i] = dataHora2[i];
for (int i = 0; i < 2; i++)
mes2[i] = dataHora2[i + 5];
dia2[i] = dataHora2[i + 8];
hora2[i] = dataHora2[i + 11];
minuto2[i] = dataHora2[i + 14];
segundo2[i] = dataHora2[i + 17];
anoInt2 = atol(ano2);
mesInt2 = atol(mes2);
diaInt2 = atol(dia2);
horaInt2 = atol(hora2);
minInt2 = atol(minuto2);
segInt2 = atol(segundo2);
rtc.setTime(segInt2, minInt2, horaInt2, diaInt2, mesInt2, anoInt2);
Output:
14:35:56.586 -> WiFi connected.
14:35:56.586 -> IP address:
14:35:56.586 -> 192.168.1.184
14:35:56.586 -> Conectado
14:35:56.586 -> Define DATA
14:35:56.865 -> TIMESTAMP
14:35:56.865 -> 1671456956
14:35:56.865 -> 2022-12-19T13:35:56Z
14:35:56.865 -> DATE:
14:35:56.865 -> HOUR:
14:35:56.865 -> 13:35:56
However, I decided to put a Wifimanager library (GitHub - tzapu/WiFiManager: ESP8266 WiFi Connection manager with web captive portal) to facilitate the connection:
#include <WiFi.h>
#include <ESP_WiFiManager.h>
#include <EEPROM.h>
#include <WebServer.h>
WebServer server(80);
String header;
WiFiUDP ntpUDP;
ESP32Time rtc;
#define PIN_LED 2
#define ESP_getChipId() ((uint32_t)ESP.getEfuseMac())
// SSID and PW for Config Portal
String ssid = "ESP_" + String(ESP_getChipId(), HEX);
const char* password = "your_password";
// SSID and PW for your Router
String Router_SSID;
String Router_Pass;
// Indicates whether ESP has WiFi credentials saved from previous session
bool initialConfig = false;
// Use true for dynamic DHCP IP, false to use static IP and you have to change the IP accordingly to your network
#define USE_DHCP_IP false
IPAddress stationIP = IPAddress(192, 168, 1, 184 /*0, 0, 0, 0*/);
IPAddress gatewayIP = IPAddress(192, 168, 1, 1 /*192, 168, 2, 1*/);
IPAddress netMask = IPAddress(255, 255, 0, 0);
IPAddress dns1IP = IPAddress(8, 8, 8, 8);
IPAddress dns2IP = IPAddress(8, 8, 4, 4);
bool shouldSaveConfig = false;
void heartBeatPrint(void)
static int num = 1;
Serial.print("H"); // H means connected to WiFi
Serial.print("F"); // F means not connected to WiFi
if (num == 80)
num = 1;
else if (num++ % 10 == 0)
Serial.print(" ");
void check_status() {
// is configuration portal requested?
Serial.println("\nConfiguration portal requested.");
digitalWrite(PIN_LED, HIGH); // turn the LED on by making the voltage LOW to tell us we are in configuration mode.
//Local intialization. Once its business is done, there is no need to keep it around
ESP_WiFiManager ESP_wifiManager;
ESP_wifiManager.setSaveConfigCallback(saveConfigCallback);
//Check if there is stored WiFi router/password credentials.
//If not found, device will remain in configuration mode until switched off via webserver.
Serial.print("Opening configuration portal. ");
Router_SSID = ESP_wifiManager.WiFi_SSID();
if (Router_SSID != "")
ESP_wifiManager.setConfigPortalTimeout(120); //If no access point name has been previously entered disable timeout.
Serial.println("Got stored Credentials. Timeout 120s");
Serial.println("No stored Credentials. No timeout");
ESP_wifiManager.setMinimumSignalQuality(-1);
// Set static IP, Gateway, Subnetmask, DNS1 and DNS2. New in v1.0.5
ESP_wifiManager.setSTAStaticIPConfig(stationIP, gatewayIP, netMask, dns1IP, dns2IP);
//it starts an access point
//and goes into a blocking loop awaiting configuration
if (!ESP_wifiManager.startConfigPortal((const char *) ssid.c_str(), password))
Serial.println("Not connected to WiFi but continuing anyway.");
//if you get here you have connected to the WiFi
Serial.println("connected...yeey :)");
Serial.print("Local IP: ");
digitalWrite(PIN_LED, LOW); // Turn led off as we are not in configuration mode.
static ulong checkstatus_timeout = 0;
#define HEARTBEAT_INTERVAL 10000L
// Print hearbeat every HEARTBEAT_INTERVAL (10) seconds.
if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
heartBeatPrint();
checkstatus_timeout = millis() + HEARTBEAT_INTERVAL;
Serial.println("Reiniciando");
ESP.restart();
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void connectWifi() {
Serial.println("\nStarting ConfigOnSwitch on " + String(ARDUINO_BOARD));
unsigned long startedAt = millis();
// Use this to default DHCP hostname to ESP8266-XXXXXX or ESP32-XXXXXX
//ESP_WiFiManager ESP_wifiManager;
// Use this to personalize DHCP hostname (RFC952 conformed)
ESP_WiFiManager ESP_wifiManager("ConfigOnSwitch");
ESP_wifiManager.setDebugOutput(true);
// Use only to erase stored WiFi Credentials
//resetSettings();
//ESP_wifiManager.resetSettings();
//set custom ip for portal
//ESP_wifiManager.setAPStaticIPConfig(IPAddress(192, 168, 100, 1), IPAddress(192, 168, 100, 1), IPAddress(255, 255, 255, 0));
// We can't use WiFi.SSID() in ESP32as it's only valid after connected.
// SSID and Password stored in ESP32 wifi_ap_record_t and wifi_config_t are also cleared in reboot
// Have to create a new function to store in EEPROM/SPIFFS for this purpose
Router_Pass = ESP_wifiManager.WiFi_Pass();
//Remove this line if you do not want to see WiFi password printed
Serial.println("Stored: SSID = " + Router_SSID + ", Pass = " + Router_Pass);
// SSID to uppercase
ssid.toUpperCase();
if (Router_SSID == "")
Serial.println("Open Config Portal without Timeout: No stored Credentials.");
digitalWrite(PIN_LED, HIGH); // Turn led on as we are in configuration mode.
Serial.println("WiFi connected...yeey :)");
#define WIFI_CONNECT_TIMEOUT 30000L
#define WHILE_LOOP_DELAY 200L
#define WHILE_LOOP_STEPS (WIFI_CONNECT_TIMEOUT / ( 3 * WHILE_LOOP_DELAY ))
while ( (WiFi.status() != WL_CONNECTED) && (millis() - startedAt < WIFI_CONNECT_TIMEOUT ) )
WiFi.mode(WIFI_STA);
WiFi.persistent (true);
// We start by connecting to a WiFi network
Serial.println(Router_SSID);
WiFi.config(stationIP, gatewayIP, netMask);
//WiFi.config(stationIP, gatewayIP, netMask, dns1IP, dns2IP);
WiFi.begin(Router_SSID.c_str(), Router_Pass.c_str());
int i = 0;
while ((!WiFi.status() || WiFi.status() >= WL_DISCONNECTED) && i++ < WHILE_LOOP_STEPS)
delay(WHILE_LOOP_DELAY);
Serial.print("After waiting ");
Serial.print((millis() - startedAt) / 1000);
Serial.println(" secs more in setup(), connection result is ");
Serial.print("connected. Local IP: ");
void streamTimeoutCallback(bool timeout)
if (timeout) {
//Stream timeout occurred
Serial.println("Stream timeout, resume streaming...");
if (digitalRead(0) == LOW)
Serial.println("Modo AP...");
check_status();
connectWifi();
NTPCIniciar();
defineData();
server.begin();
void loop(){
void NTPCIniciar()
timeClient.begin();
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
void defineData() {
char ano2[5];
char mes2[3];
char dia2[3];
char hora2[3];
char minuto2[3];
char segundo2[3];
char dataHora2[21];
int anoInt2;
int mesInt2;
int diaInt2;
int horaInt2;
int minInt2;
int segInt2;
String dayStamp;
String timeStamp;
// Extract date
// Extract time
When I put it, setting exactly the same IP and network values, it generates this output:
14:35:02.332 -> After waiting 2 secs more in setup(), connection result is
14:35:02.332 -> connected. Local IP: 192.168.1.184
14:35:02.332 -> WiFi connected.
14:35:02.332 -> Define DATA
14:35:03.356 -> Update
14:35:04.378 -> TIMESTAMP
14:35:04.378 -> 4294956500
14:35:04.378 -> 2106-02-07T03:28:20Z
14:35:04.378 -> DATE:
14:35:04.378 -> HOUR:
14:35:04.378 -> 03:28:20
Dates change completely, it seems NTPC can't get the updated date.
Would anyone know how to help me with this?
I can't find what it could be.
Thank you!
