Problem using TFT and RX-TX at the same time
Dear all,
I am using an Adafruit 1947 capacitive TFT touch screen which I mounted on an Uno. I also have a Nano 33 BLE, which is connected to a sensor. I want to control a condition with the touch panel. For that, I coded the Nano to give the output to Serial1. I checked with bare Uno and it was able to communicate well with Nano. But the problem arises when I connect the TFT screen to the Uno. In that case, the Nano still sends the correct values, but the Uno gives the wrong number.
Any ideas?
PS: I have connected the two boards as described on How to make two Arduino boards talk to each other |, using resistors. I am turning on both by connecting to my PC. Long story short, Uno receives data fine w/o TFT, but when TFT is installed, it mixes up.
Welcome to the forum!
Please help people to help you. Read the "How to post". Its at the beginning of each sub forum.
General Guidance and How to use the Forum
How to use this forum - please read.
My experience is that good posts get a lot of attention and answers.
Add:
  • schematic (hand drawn photo taken with smart phone is OK, make sure it appears inside the post, see "How to post")
  • a small sketch that shows the issue (use code tags)
  • links to datasheets for non-Arduino components
