problem using the map() function..
Basically if I do this:
  pot1 = analogRead(5);                       //check to see if another wave has been selected
      waveSelect = map(pot1, 0, 1023, 0, 3);      //waveform pot, divided into 4
Then so should it go like this: waveSelect=1, pot1=0-255 waveSelect=2, pot1=255-511 waveSelect=3, pot1=512-767 waveSelect=4 pot1=768-1023
right? Becasue it's not working for me like that. Maybe I'm misunderstanding what map does?
Your map range is 0 to 3. But you are expecting values in range 1 to 4.
Not only that, but the only value in the from range that will map to the upper limit of the to range is the last value.
As specified,
pot1 = 0 - 341 ==> 0
pot1 = 342 - 682 ==> 1
pot1 = 683 - 1022 ==> 2
pot1 = 1023 ==> 3
To get the values you are expecting, you need a map call like:
waveSelect = map(pot1, 0, 1024, 1, 4);
Nadir:
oops that was just me not thinking when i started this topic, in the actual code I have it right.
PaulS:
As specified,
pot1 = 1023 ==> 3
This, is my problem. It kept changing from waveSelect 3 to 2 as soon as pot1 hit 1022. How does setting the upper bound to 1024 change things, as pot1=max 1023??
Why are you using "map" at all?
AWOL: Why are you using "map" at all?
That way it's simpler if I want to change my code and want to divide by 5,6 or whatever, it's easy. I can just change that one line. For other ways(as far as I know), I'd have to change a lot more code..
Can't disagree there. ;)
Look at the map function:
long map(long x, long in_min, long in_max, long out_min, long out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
in_min and out_min are both 0 in your initial map call, so map looks like: return (x) * (out_max) / (in_max); With out_max equal 3 and in_max = 1023, the map function looks like: return x * 3 / 1023; The only value for x that results in returning 3 is 1023. If you change in_max and out_max to 4 and 1024, the function looks like return x * 4 / 1024; Now, any value of x over 767 will return 3. The maximum input value, 1023, will return 3.
So, if you want values from 0 to 3 to be returned, you need to call map: waveSelect = map(pot1, 0, 1024, 0, 4);
If you want values from 1 to 4: waveSelect = map(pot1, 0, 1024, 1, 5);
(Yes, I had the wrong to range).
Thanks for that, all makes sense now. :) I was scratching my head there for a while.
WoW.. Learned something new.. :P
