Problem using 'Timer' library
Hello! I am facing a problem regarding the use of Timer library in my code. I got this code from Internet for my project. My board is Arduino Uno.
Here is my code :
#define USE_ARDUINO_INTERRUPTS true
#define DEBUG true
#define SSID “" // “SSID-WiFiname”
#define PASS "
****” // “password”
#define IP “184.106.153.149” // thingspeak.com ip
#include <SoftwareSerial.h>
#include “Timer.h”
#include <PulseSensorPlayground.h> // Includes the PulseSensorPlayground Library.
Timer t;
PulseSensorPlayground pulseSensor;
String msg = “GET /update?key=your api key”;
SoftwareSerial esp8266(10,11);
//Variables
const int PulseWire = A0; // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED13 = 13; // The on-board Arduino LED, close to PIN 13.
int Threshold = 550; //for heart rate sensor
float myTemp;
int myBPM;
String BPM;
String temp;
int error;
int panic;
int raw_myTemp;
float Voltage;
float tempC;
esp8266.begin(115200);
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED13); //auto-magically blink Arduino’s LED with heartbeat.
pulseSensor.setThreshold(Threshold);
// Double-check the “pulseSensor” object was created and “began” seeing a signal.
if (pulseSensor.begin()) {
Serial.println(“We created a pulseSensor Object !”); //This prints one time at Arduino power-up, or on Arduino reset.
Serial.println(“AT”);
esp8266.println(“AT”);
delay(3000);
if(esp8266.find(“OK”))
connectWiFi();
t.every(10000, getReadings);
t.every(10000, updateInfo);
panic_button();
start: //label
error=0;
t.update();
//Resend if transmission is not completed
if (error==1)
goto start; //go to label “start”
delay(4000);
void updateInfo()
String cmd = “AT+CIPSTART=“TCP”,”";
cmd += IP;
cmd += “”,80";
Serial.println(cmd);
esp8266.println(cmd);
delay(2000);
if(esp8266.find(“Error”))
return;
cmd = msg ;
cmd += “&field1=”; //field 1 for BPM
cmd += BPM;
cmd += “&field2=”; //field 2 for temperature
cmd += temp;
cmd += “\r\n”;
Serial.print(“AT+CIPSEND=”);
esp8266.print(“AT+CIPSEND=”);
Serial.println(cmd.length());
esp8266.println(cmd.length());
if(esp8266.find(">"))
Serial.print(cmd);
esp8266.print(cmd);
Serial.println(“AT+CIPCLOSE”);
esp8266.println(“AT+CIPCLOSE”);
//Resend…
error=1;
boolean connectWiFi()
Serial.println(“AT+CWMODE=1”);
esp8266.println(“AT+CWMODE=1”);
delay(2000);
String cmd=“AT+CWJAP=”";
cmd+=SSID;
cmd+="","";
cmd+=PASS;
cmd+=""";
delay(5000);
return true;
return false;
void getReadings(){
raw_myTemp = analogRead(A1);
Voltage = (raw_myTemp / 1023.0) * 5000; // 5000 to get millivots.
tempC = Voltage * 0.1;
myTemp = (tempC * 1.8) + 32; // conver to F
Serial.println(myTemp);
int myBPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an “int”.
// “myBPM” hold this BPM value now.
if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if “a beat happened”.
Serial.println(myBPM); // Print the value inside of myBPM.
delay(20);
char buffer1[10];
char buffer2[10];
BPM = dtostrf(myBPM, 4, 1, buffer1);
temp = dtostrf(myTemp, 4, 1, buffer2);
void panic_button(){
panic = digitalRead(8);
if(panic == HIGH){
Serial.println(panic);
cmd += IP;
cmd += “”,80";
delay(2000);
return;
cmd = msg ;
cmd += “&field3=”;
cmd += panic;
cmd += “\r\n”;
Serial.print(cmd);
esp8266.print(cmd);
//Resend…
error=1;
The error messages displayed are :
Arduino: 1.8.6 (Windows 7), Board: “Arduino/Genuino Uno”
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino: In function ‘void setup()’:
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino:53:23: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
iot_project2:57:28: error: no matching function for call to ‘Timer::every(int, void (&)())’
In file included from C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino:2:0:
C:\Users\HP\Documents\Arduino\libraries\Timer-2.1/Timer.h:40:10: note: candidate: int8_t Timer::every(long unsigned int, void ()(void), void*)
int8_t every(unsigned long period, void (callback)(void), void* context);
C:\Users\HP\Documents\Arduino\libraries\Timer-2.1/Timer.h:40:10: note: candidate expects 3 arguments, 2 provided
C:\Users\HP\Documents\Arduino\libraries\Timer-2.1/Timer.h:41:10: note: candidate: int8_t Timer::every(long unsigned int, void ()(void), int, void*)
int8_t every(unsigned long period, void (callback)(void), int repeatCount, void* context);
C:\Users\HP\Documents\Arduino\libraries\Timer-2.1/Timer.h:41:10: note: candidate expects 4 arguments, 2 provided
iot_project2:58:27: error: no matching function for call to ‘Timer::every(int, void (&)())’
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino: In function ‘void updateInfo()’:
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino:83:26: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino:97:22: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino: In function ‘boolean connectWiFi()’:
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino:124:23: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino: In function ‘void panic_button()’:
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino:163:26: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
C:\Users\HP\Documents\Arduino\sketch_feb19a\iot_project2\iot_project2.ino:175:22: warning: ISO C++ forbids converting a string constant to ‘char*’ [-Wwrite-strings]
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
Welcome to the fourms. Please read the sticky post at the top of the forum about how to properly post your code and error messages using code tags. It will help people help you.
Those error messages seem pretty straight forward, don't they? You have to cast those string constants to 'char *'. It also looks like you are caller your Timer functions incorrectly.
