Problem using ultrasound sensor
Hello Guys,
So I was asked to make a small system that detects ultrasound waves and read them in arduino. So I looked up in the forum and found a topic that helped me:
https://forum.arduino.cc/index.php?topic=533288.0
jremington:
Perhaps you could replace the MEMS microphone on a typical microphone module with one of the transducers.
Most MEMS microphones are useless above 20 kHz. The HC-SR04 transducers are resonant at about 40 kHz, so they will be most sensitive to frequencies near that. It is not possible to change the resonant frequency.
So I did that and I think it works but still I don't know how to extract informations from the results.
Here is what I get when there is no source of 40kHz wave:
Here is what I get when I put the source(HC-SR04) in range:
My goal in the assignement is to be able to get a graph showing the 40kHz frequency when the wave is present. But if I can get a digital value instead of the values shown in the images above that would be enough.
The sketch code is in attachements.
Thanks
UltrasoundTest.ino (609 Bytes)
Please post your code and a schematic.
TheMemberFormerlyKnownAsAWOL:
Thanks for your reply. The schematic is very easy I just connected every pin to its port(I don't know how to make schematics as I am new in arduino things).
Here is the code:
/* Constantes pour les broches */
const byte TRIGGER_PIN = 2; // Broche TRIGGER
 pinMode(A0,INPUT);
/* Initialise le port série */
 /* Initialise les broches */
 pinMode(TRIGGER_PIN, OUTPUT);
 digitalWrite(TRIGGER_PIN, LOW); // La broche TRIGGER doit être à LOW au repos
 digitalWrite(TRIGGER_PIN, HIGH);
 delayMicroseconds(10);
 int SensorData=analogRead(A0);
 Serial.println(SensorData);
 delay(50);
What is connected to pin A0?
Please remember to use code tags when posting code
A0 is connected to the Analog output of the sound sensor(KY-038) that has the receiver transducer that I removed from HC-SR04
thanks I will use them next time.
The HC-SR04 sends only a very short burst of ultrasonic waves when triggered.
A single analogRead() probably will not capture anything useful, especially when followed by a very slow Serial.print(). In any case, analogRead() is far too slow to measure signals at ultrasonic frequencies.
40kHz is one cycle every 25 microseconds.
An SR04, when triggered, typically produces a pulse train of 8 cycles, or 200 microseconds. With ringing, maybe another 100 or so microseconds.
What do you expect to achieve by taking a single sample?
jremington:
Thanks for the reply.
What do you suggest I do?
I want to get just the frequency at each pulse.
WalidMogo:
The frequency will be 40kHz.
Yes I know, How would I show it somehow? or atleast get a digital output when there are waves?
To capture 40 kHz waves, you need a much more sophisticated circuit. You would need at minimum an amplifier capable of responding to ultrasonic frequencies, most likely followed by a precision rectifier and peak detector, or fast digital sampling of the amplified signal.
jremington:
Thank you so much for your reply.
Okay I will try to do that. Let's suppose that it worked, now how would I get exactly the frequency? because the whole purpose of this project is to get different kinds of ultrasonic waves and identify them by frequency, the 40kHz pulses from HC-SR04 are just for testing.
Hack a bat detector?
