problem using void
im just playing around with my project
im trying to build a smart home and right now working on a code for auto on/off of the room lights
im not that good with the language so im pretty much a newbie… but i just cant find the error in my code please help me
int val=0;
int val2=0;
int InputPin=A0;
int InputPin2=A2;
int OutputPin=0;
int checkinc=0;
 digitalWrite(OutputPin, LOW);
  val = analogRead(InputPin);        // read the input pin 0 to 1023
  Serial.println("valume ONE is:");
  Serial.println(val);
  if(val>500 && val2<500){
  checkin();
  val2 = analogRead(InputPin2);        // read the input pin 0 to 1023
  Serial.println("valume TWO is:");
  Serial.println(val2);
  if(val2>500 && val<500){
  checkout();
void checkin();{
  if(val2>500 && val>500){
    checkinc=checkinc+1;
    if(checkinc>=1){
    digitalWrite(OutputPin, HIGH);
void checkout(){
    checkinc=checkinc-1;
    if(checkinc<=0){
      if(checkinc<0){
      checkinc=0;
and thats the error im getting:
Arduino: 1.6.7 (Windows 7), Board: "Arduino Nano, ATmega328"
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SoftwareSerial is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
C:\Users\Yoad\Documents\Arduino\RF_CHECK\RF_CHECK.ino: In function 'void loop()':
RF_CHECK:22: error: 'checkin' was not declared in this scope
   checkin();
RF_CHECK:30: error: 'checkout' was not declared in this scope
   checkout();
RF_CHECK:39: error: assignment of function 'void checkin()'
     checkin=checkin+1;
RF_CHECK:39: error: cannot convert 'void (*)()' to 'void()' in assignment
RF_CHECK:40: error: ISO C++ forbids comparison between pointer and integer [-fpermissive]
     if(checkin>=1){
RF_CHECK:45: error: a function-definition is not allowed here before '{' token
 void checkout(){
RF_CHECK:58: error: expected '}' at end of input
exit status 1
  enabled in File > Preferences.
i dont know whats wrong i looked at like 1000000 other codes that used void (X) in the same way…
void checkin();{
remove the semicolon - there's no semicolon in a function declaration.
See what errors you get after that and post them.
It also looks like that code is not the code that produced those errors. The compiler error output mentions a lot of places where math was performed with "checkin" and it rightly complained, because checkin is a function - but in your code, I see you've changed all those to checkinc... so can you post latest code and compiler output too?
it was left there from the 1000 changes ive made trying to make this code run.. my mistake. and thats the code im using right now (the one from the begining)
but now thats the error:
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Nano, ATmega328"
rf_check.ino: In function 'void loop()':
rf_check:33: error: a function-definition is not allowed here before '{' token
rf_check:57: error: expected '}' at end of input
  checkout();
Needs more }
AWOL:
checkout();
Needs more }
yea i noticed that i was missing a few and add them yet that not the real problem here:/ (i think…)
yet that not the real problem here:/ (i think..)
You think incorrectly.
Post your code.
Ctrl+T to autoformat code in the IDE - this makes problems with mismatched braces much easier to see.
AWOL:
Post your code.
int val=0;
int val2=0;
int InputPin=A0;
int InputPin2=A2;
int OutputPin=0;
int checkinc=0;
void loop(){
  digitalWrite(OutputPin, HIGH);    // sets the output pin initially to LOW
  checkin();
  checkout();  }
void checkin(){
    if(checkinc>=1){
void checkout(){
    if(checkinc<=0){
      if(checkinc<0){
      checkinc=0;
See reply #3
AWOL: See reply #3
i got enough i checked twice every { has a } i dont think ive missed anything in there.. but still the main problem is in the voids idk whats wrong :(
Put every { on a line by itself. Put every } on a line by itself. Get back to us when every { has a matching }
I didn't need to check that many times
Each opening brace does have a closing one, I think - but they're totally not in the right place.
Find the matching brace to the one opening loop() function definition...
It is not valid C to put a function definition inside another function - but that's what you've got due to misplaced }.
