problem using while
this is my code:
Serial.println("Enter number: ");
while (Serial.available()==0);
int val=Serial.parseInt();
Serial.println(val);
when I execute the Sketch and input 5 I expect this:
Enter number:
5
Enter number:
But what I get is this:
Enter number:
5
Enter number:
0
Enter number:
What am I doing wrong?
Have a look at this example of how ‘serialavailable’ works,
https://www.arduino.cc/reference/en/language/functions/communication/serial/available?from=Reference.SerialAvailable
You are basically only looking for data when there is none ; If you use : while(Serial.available()==0){ }
Then it will wait in this loop whilst no data is available, and when there is some execute the code that follows .
@hammy, that would not make a difference as far as I know; there is a semi-colon after the while.
@mac-7, what is the line-ending in serial monitor set to? Set it to 'none' if it isn't.
@mac-7
Moved your topic to it’s current location / section as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
