Problem using Wokwi with SpeedyStepper.h library
I haven't found a way to contact the Wokwi people, and I'm not sure I'm using the right place here on the Arduino forum.
If the location is not correct, I ask moderators to direct my post to the correct location. Thanks
When simulating a code to help a friend here,
I encountered a problem with the Wokwi simulator.
I reduced the code to the maximum and still the error happens.
The screen below shows the error, I attach the code that produces the error.
The cause is the arduino.h library included by the library
SpeedyStepper.h.
But it is not possible to include the arduino.h library in the library tab.
#include <arduino.h>
#include <SpeedyStepper.h>
I use wokwi, and I use Arduino with the IDE.
In neither case have I ever
# include <arduino.h>
So lose that.
If your next problem is a failure to find the other included file, that may be because it has not been accepted by the wokwi people.
Who, BTW, are very easy to reach and quite responsive. I got to the GitHub site after going to the "Docs" section from the main wokwi page:
Wokwi GitHub repository
You might start with the wokwi-features section, for feature requests and bug reports.
HTH
a7
If you go to the Library Manager tab on the wokwi simulation, you can type the first few characters and it will turn up SpeedyStepper so you can add it as a library.
At least it does for me. I am a registered user and a supporter, I do know that some stuff is only available to non-anonymous users, so.
HTH
a7
Did you try running OP's empty sketch in post 1? I just tried doing this as a free user and I also got the same bug, even when adding in the appropriate library in the library manager, so it sounds like it's a wokwi problem.
Perhaps so.
wokwi doesn't like <arduino.h> but is cool with <Arduino.h>.
SpeedyStepper includes <arduino.h>, which looks like wokwi's problem with using that library.
Work around and get back to draining the swamp: the SpeedyStepper library is exactly two source files, add both to to your woki project just like you'd do in the IDE. And fix the case sensitivity problem...
a7
First I tried the code with the SpeedyStepper.h library using libray manager, without including the arduino.h library.
As the error occurred, I included the arduino.h library in the code.
Including <arduino.h> // not Arduino.h...
works in the IDE
doesn't work in the wokwi
Neither directly including it or having some library try to drag it in will work in the wokwi.
There is something about the case sensitivity differences going on here.
Drop the wokwi boys a note about that. In the meantime just tab in the files you need.
a7
Tks, I will.
Got it to compile and run by placing the library into the tabs, as per a7's suggestion.
It also seems like you need to have a library included in Quotation marks, instead of "<" and ">", when you add the library into the tabs.
So you have #include "mylib.h" instead of #include <mylib.h>, in your main sketch.
I also added a full example sketch from the library, to confirm all the functions were being recognized.
