Problem uusing delay for power saving keypad logger
I am working on a project that includes keypad and rtc with uno
It sleeps in between key presses to save battery.
the code for power saving keypad is taken from
http://www.gammon.com.au/forum/?id=11497
(find “Detecting key presses on a keypad whilst asleep”)
added rtc and sd functionality
i want my arduino to get key press from keypad , print it to a text file in sdcard along with timestamp,
AND IF NO KEY IS PRESSED FOR PAST 5 SECONDS → GO TO SLEEP
now the problem is that the arduino goes to sleep after every key press which i dont want.
any suggetions??
// Wake from deep sleep with a keypress demonstration
// Author: Nick Gammon
// Date: 18th November 2012
#include <Keypad.h>
#include <avr/sleep.h>
#include <avr/power.h>
#include <Wire.h>
#include "RTClib.h"  // Credit: Adafruit
RTC_DS1307 RTC;
#include <SD.h> //added for sd
const int chipSelect = 10; //added for sd
File myFile;  //added for sd
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] =
    {'1', '2', '3', 'A'},
    {'4', '5', '6', 'B'},
    {'7', '8', '9', 'C'},
    {'*', '0', '#', 'D'},
byte rowPins[ROWS] = {6, 7, 8, 9}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {2, 3, 4, 5}; //connect to the column pinouts of the keypad
// number of items in an array
#define NUMITEMS(arg) ((unsigned int) (sizeof (arg) / sizeof (arg [0])))
const byte sdpin = 14;
  // Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
Pin change interrupts.
Pin                  Mask / Flag / Enable
D0	  PCINT16 (PCMSK2 / PCIF2 / PCIE2)
D1	  PCINT17 (PCMSK2 / PCIF2 / PCIE2)
D2	  PCINT18 (PCMSK2 / PCIF2 / PCIE2)
D3	  PCINT19 (PCMSK2 / PCIF2 / PCIE2)
D4	  PCINT20 (PCMSK2 / PCIF2 / PCIE2)
D5	  PCINT21 (PCMSK2 / PCIF2 / PCIE2)
D6	  PCINT22 (PCMSK2 / PCIF2 / PCIE2)
D7	  PCINT23 (PCMSK2 / PCIF2 / PCIE2)
D8	  PCINT0 (PCMSK0 / PCIF0 / PCIE0)
D9	  PCINT1 (PCMSK0 / PCIF0 / PCIE0)
D10	  PCINT2 (PCMSK0 / PCIF0 / PCIE0)
D11	  PCINT3 (PCMSK0 / PCIF0 / PCIE0)
D12	  PCINT4 (PCMSK0 / PCIF0 / PCIE0)
D13	  PCINT5 (PCMSK0 / PCIF0 / PCIE0)
A0	  PCINT8 (PCMSK1 / PCIF1 / PCIE1)
A1	  PCINT9 (PCMSK1 / PCIF1 / PCIE1)
A2	  PCINT10 (PCMSK1 / PCIF1 / PCIE1)
A3	  PCINT11 (PCMSK1 / PCIF1 / PCIE1)
A4	  PCINT12 (PCMSK1 / PCIF1 / PCIE1)
A5	  PCINT13 (PCMSK1 / PCIF1 / PCIE1)
// turn off interrupts until we are ready
ISR (PCINT0_vect)
  PCICR = 0;  // cancel pin change interrupts
  } // end of ISR (PCINT0_vect)
ISR (PCINT1_vect)
  } // end of ISR (PCINT1_vect)
ISR (PCINT2_vect)
  } // end of ISR (PCINT2_vect)
void setup ()
    Wire.begin();
  RTC.begin();
    pinMode(10, OUTPUT);
  pinMode (sdpin, OUTPUT);
  // pin change interrupt masks (see above list)
  PCMSK2 |= bit (PCINT22);   // pin 6
  PCMSK2 |= bit (PCINT23);   // pin 7
  PCMSK0 |= bit (PCINT0);    // pin 8
  PCMSK0 |= bit (PCINT1);    // pin 9
  }  // end of setup
// set pins as keypad library expects them
// or call: kpd.initializePins ();
//    however in the library I have that is a private method
void reconfigurePins ()
  byte i;
  // go back to all pins as per the keypad library
  for (i = 0; i < NUMITEMS (colPins); i++)
    pinMode (colPins [i], OUTPUT);
    digitalWrite (colPins [i], HIGH);
    }  // end of for each column
  for (i = 0; i < NUMITEMS (rowPins); i++)
    pinMode (rowPins [i], INPUT);
    digitalWrite (rowPins [i], HIGH);
    }   // end of for each row
  }  // end of reconfigurePins
void goToSleep ()
  byte i;
  // set up to detect a keypress
    digitalWrite (colPins [i], LOW);   // columns low
    digitalWrite (rowPins [i], HIGH);  // rows high (pull-up)
   // now check no pins pressed (otherwise we wake on a key release)
    if (digitalRead (rowPins [i]) == LOW)
       reconfigurePins ();
       return;
       } // end of a pin pressed
  // overcome any debounce delays built into the keypad library
  delay (50);
  // at this point, pressing a key should connect the high in the row to the
  // to the low in the column and trigger a pin change
  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  byte old_ADCSRA = ADCSRA;
  // disable ADC to save power
  ADCSRA = 0;
  power_all_disable ();  // turn off various modules
  PCIFR  |= bit (PCIF0) | bit (PCIF1) | bit (PCIF2);   // clear any outstanding interrupts
  PCICR  |= bit (PCIE0) | bit (PCIE1) | bit (PCIE2);   // enable pin change interrupts
  // turn off brown-out enable in software
  MCUCR = bit (BODS) | bit (BODSE);
  MCUCR = bit (BODS);
  sleep_cpu ();
  // cancel sleep as a precaution
  sleep_disable();
  power_all_enable ();   // enable modules again
  ADCSRA = old_ADCSRA;   // re-enable ADC conversion
  // put keypad pins back how they are expected to be
  reconfigurePins ();
  }  // end of goToSleep
void loop ()
   char key =  kpd.getKey();
   if (!key)
     // no key pressed? go to sleep
     goToSleep ();
     return;
  // confirmation we woke - flash LED number of times
  // for the appropriate pin (eg. pin 1: one time)
  else if (key)
   digitalWrite(sdpin, HIGH);   // turn the sd card high
       SD.begin(10);
           myFile = SD.open("log.txt", FILE_WRITE);
           myFile.println();
                   DateTime now = RTC.now();
  // Display the current time
                    myFile.print("Current time: ");
                    myFile.print(now.year(), DEC);
                    myFile.print('/');
                    myFile.print(now.month(), DEC);
                    myFile.print('/');
                    myFile.print(now.day(), DEC);
                    myFile.print(' ');
                    myFile.print(now.hour(), DEC);
                    myFile.print(':');
                    myFile.print(now.minute(), DEC);
                    myFile.print(':');
                    myFile.print(now.second(), DEC);
                    myFile.println();
           myFile.print(key);
           myFile.close();
  digitalWrite(sdpin, LOW);    // turn the sd card low
  } // end of loop
   if (!key)
     goToSleep ();
     return;
Make this
    if(it's been more than 5 seconds)
       goToSleep();
It is not difficult to determine when things happen, using millis() or what time it is now (same function).
#include <Keypad.h>
#include <Wire.h>
RTC_DS1307 RTC;
ISR (PCINT0_vect)
ISR (PCINT1_vect)
ISR (PCINT2_vect)
void setup ()
    Wire.begin();
  RTC.begin();
  }  // end of setup
  byte i;
void goToSleep ()
  byte i;
       reconfigurePins ();
       return;
  delay (50);
  sleep_enable();
  ADCSRA = 0;
  MCUCR = bit (BODS);
  sleep_cpu ();
  sleep_disable();
  reconfigurePins ();
void loop ()
   unsigned long ctime=millis();
   while(millis()-ctime<5000)
       if (key)
              ctime=millis();                               //also try one more time by uncommenting this
       SD.begin(10);
           myFile.println();
                    myFile.print('/');
                    myFile.print('/');
                    myFile.print(' ');
                    myFile.print(':');
                    myFile.print(':');
                    myFile.println();
  myFile.print(key);
           myFile.close();
   else if (!key)
     goToSleep ();
     return;
i just updated the code do you think it is right now?
my arduino is not with me right now. In two hours ill test this code
No. You should record when you get a key. When no key is pressed, check how long it has been since a key was pressed. If more than 5 seconds, clear the last key time and go to sleep. The last key pressed time needs to be static or global.
