Greetings,
I recently got an Electronic DC Load from ebay, and i am trying to implement and arduino controller into it.
The arduino is going to do the following things.
- Drive the display (planning on an OLED)
- Display Voltage
- Display Current
- Display Temprature
- Controll a digital potentiometer
- Dataloging to a pc or SD card.
Currently i am still designing the arduino circuit that is going to sit on a custom PCB.
Now the problem:
I am trying to use an ADC (analog to digital converter) to measure the voltage of the load, aswell as measure the voltage accross a current sensing resistor. The problem is that i need to power the ADC from the Arduino's & Load's power supply, while measuring an alltogether diferent curcuit. I undestand the concept of common grounding, but having measured the Load's Ground and the Load's Load ground (yes, you read that right),i see a 320kΩ resistance between them, and i feel reluctant to merge them without knowing what that resistance is.
The load itself is this one: LM324 electronic load - Xiaolin
https://www.ebay.com/itm/150W-72V-10A-Constant-Current-Electronic-Load-Battery-Discharge-Capacity-Tester/282754292642?hash=item41d5781ba2:g:cekAAOSwbw1aH31r
Any insight would be greatly appreciated.
Thank you for your time.
