hello, I’m having difficulty with the W5100S chip, I’m using it in conjunction with the Arduino libraries but I can’t ping the W5100S, however when I use a shield with the W5100 everything works normally. I would like to know if there would be any special configuration in the arduino library that I can prevent from working?
I am available to send any support material that is necessary.
Post your schematic. Post a link to the 5100 based board that you have. And post your code.
And look at the datasheets to find the differences between the two chips.
@sterretje this is my diagram and it is based on the Wiznet application note
https://wizwiki.net/wiki/doku.php/products:w5100s:refschematic
