Problem when read data from Schneider PM1200 by Arduino MEGA 2560
  1. Mission
     Read data from registers of Schneider PM1200 by Arduino ( Modbus Master)
     Link : http://www2.schneider-electric.com/resources/sites/SCHNEIDER_ELECTRIC/content/live/FAQS/212000/FA212509/en_US/PM1000_User_Guide.pdf (page 53)
  2. Connection Diagram
    Devices include:
     Arduino Mega 2560
     Module RS485 – MAX485
     PM1200
  3. Library and code
     I use Modbus Master library.
     Link library: https://github.com/smarmengol/Modbus-Master-Slave-for-Arduino
     Code read data from register 3927
    Modbus by thangbaolong1601
  4. Problem
     When I run code in IDE Arduino, monitor display error 226 – Time out
    I tried to use Arduino Nano, the monitor still displayed that error.
     Then I remove Arduino and just use RS485.
     When I use Modscan software. I can completely read data from device
     When I use QModMaster software. I can not read data and program notify error Time out
    Program sent exactly request but there is nothing returning.
    If I know why, please support me.
hy....
i have same problem with comunication PM1200 and arduino with RS485....
help mi please....
thanks....
Serial is dedicated to PC (USB) communication. You should use one of the extra Serial devices of the Mega for communication with other devices.
hy…
i was succes read the data from PM2120, and the problem is, how to convert signed data to the float…
help one more…
#include <SimpleModbusMaster.h>
//////////////////// Port information ///////////////////
#define baud 9600
#define timeout 100
#define polling 20 // the scan rate
#define retry_count 10
// used to toggle the receive/transmit pin on the driver
#define TxEnablePin 2
// The total amount of available memory on the master to store data
#define TOTAL_NO_OF_REGISTERS 30
// This is the easiest way to create new packets
// Add as many as you want. TOTAL_NO_OF_PACKETS
// is automatically u pdated.
enum
  PACKET1,
  PACKET2,
  //  PACKET3,
  //  PACKET4,
  //  PACKET5,
  //  PACKET6,
  //  PACKET7,
  //  PACKET8,
  //  PACKET9,
  //  PACKET10,
  //  PACKET11,
  //  PACKET12,
  //  PACKET13,
  //  PACKET14,
  //  PACKET15,
  //  PACKETn,
  TOTAL_NO_OF_PACKETS // leave this last entry
// Create an array of Packets to be configured
Packet packets[TOTAL_NO_OF_PACKETS];
// Masters register array
unsigned int regs[TOTAL_NO_OF_REGISTERS];
  // Initialize each packet
  //    Serial1.begin(9600);READ_HOLDING_REGISTERS 43118
  //  modbus_construct(&packets[PACKET1], 1(adres PM710 sampai ke n), READ_INPUT_REGISTERS, 4010(adress registry), 1(jenis data), 10(pengurutan data sampai ke n));
  modbus_construct(&packets[PACKET1], 1, READ_HOLDING_REGISTERS, 3027, 2, 10); //L-N                  //A
  modbus_construct(&packets[PACKET2], 1, READ_HOLDING_REGISTERS, 3109, 2, 11); //Frekuency            //B
  //    modbus_construct(&packets[PACKET3], 1, READ_INPUT_REGISTERS, 4032, 1, 12); //A-N                  //C
  //    modbus_construct(&packets[PACKET4], 1, READ_INPUT_REGISTERS, 4033, 1, 13); //B-N                  //D
  //    modbus_construct(&packets[PACKET5], 1, READ_INPUT_REGISTERS, 4034, 1, 14); //C-N                  //E
  //    modbus_construct(&packets[PACKET6], 2, READ_INPUT_REGISTERS, 3998, 2, 15); //REAL ENERGY          //F
  //    modbus_construct(&packets[PACKET7], 1, READ_INPUT_REGISTERS, 4005, 1, 16); //REAL POWER           //G
  //    modbus_construct(&packets[PACKET8], 1, READ_INPUT_REGISTERS, 4006, 1, 17); //AMP POWER            //H
  //    modbus_construct(&packets[PACKET9], 1, READ_INPUT_REGISTERS, 4007, 1, 18); //KVAR DAYA REAKTIF    //I
  //    modbus_construct(&packets[PACKET10], 1, READ_INPUT_REGISTERS, 4029, 1, 19); //A-B                  //J
  //    modbus_construct(&packets[PACKET11], 1, READ_INPUT_REGISTERS, 4030, 1, 20); //B-C                  //K
  //    modbus_construct(&packets[PACKET12], 1, READ_INPUT_REGISTERS, 4031, 1, 21); //C-A                  //L
  //    modbus_construct(&packets[PACKET13], 1, READ_INPUT_REGISTERS, 4019, 1, 22); //ARUS A               //M
  //    modbus_construct(&packets[PACKET14], 1, READ_INPUT_REGISTERS, 4020, 1, 23); //ARUS B               //N
  //    modbus_construct(&packets[PACKET15], 1, READ_INPUT_REGISTERS, 4021, 1, 24); //ARUS C               //O
  //modbus_construct(&packets[PACKET2], 3, PRESET_MULTIPLE_REGISTERS, 0, 1, 20);
  Valid modbus byte formats are:
  SERIAL_8N2: 1 start bit, 8 data bits, 2 stop bits
  SERIAL_8E1: 1 start bit, 8 data bits, 1 Even parity bit, 1 stop bit
  SERIAL_8O1: 1 start bit, 8 data bits, 1 Odd parity bit, 1 stop bit
  // Initialize the Modbus Finite State Machine
  modbus_configure(&Serial3, baud, SERIAL_8N1, timeout, polling, retry_count, TxEnablePin, packets, TOTAL_NO_OF_PACKETS, regs);
  modbus_update();
  int A, B, C, D, E, F, G, H, I, J, K, L, M, N, O;
  A = regs[10];
  B = regs[11];
  //    C = regs[12];
  //    D = regs[13];
  //    E = regs[14];
  //    F = regs[15];
  //    G = regs[16];
  //    H = regs[17];
  //    I = regs[18];
  //    J = regs[19];
  //    K = regs[20];
  //    L = regs[21];
  //    M = regs[22];
  //    N = regs[23];
  //    O = regs[24];
  //    n = regs[n];
  Serial.print("A = ");
  Serial.println(A);
//  Serial.println(A / 77.69624);
  Serial.print("B = ");
    Serial.println(B);
//  Serial.println(B / 333.333333);
  //    Serial.print("C = ");
  //    Serial.println(C/10);
  //    Serial.print("D = ");
  //    Serial.println(D/10);
  //    Serial.print("E = ");
  //    Serial.println(E/10);
  //    Serial.print("F = ");
  //    Serial.println(F);
  //    Serial.print("G = ");
  //    Serial.println(G);
  //    Serial.print("H = ");
  //    Serial.println(H);
  //    Serial.print("I = ");
  //    Serial.println(I);
  //    Serial.print("J = ");
  //    Serial.println(J);
  //    Serial.print("K = ");
  //    Serial.println(K);
  //    Serial.print("L = ");
  //    Serial.println(L);
  //    Serial.print("M = ");
  //    Serial.println(M);
  //    Serial.print("N = ");
  //    Serial.println(N);
  //    Serial.print("O = ");
  //    Serial.println(O);
  Serial.println("============================================");
  //Voltage2 = regs[12];
  //Serial.print("Voltage L-N : ");
  //Serial.print(Voltage);
  //Serial.println(" V");
  //Serial.println(Voltage1);
  //Serial.println(Voltage2);
  //Serial.println(regs[10]);
  //Serial.println(regs[11]);
  //  Serial.println("DEBUG                     || OUTPUT");
  //  Serial.print("requests: ");
  //  Serial.print(packets[PACKET1].requests);
  //    Serial.print(" || Voltage L-N :");
  //    Serial.println(Voltage);
  //    Serial.print(Voltage/10);
  //    Serial.println("   Volt");
  //    Serial.println("=======================================");
  //    Serial.print(" || Frekuency   :");
  //    Serial.print(F/100);
  //    Serial.println(" Hz");
  //              Serial.println(" V");
  Serial.print("successful_requests: ");
  Serial.println(packets[PACKET1].successful_requests);
  Serial.println("                        || ");
  Serial.print("failed_requests: ");
  Serial.print(packets[PACKET1].failed_requests);
  Serial.print("exception_errors: ");
  Serial.print(packets[PACKET1].exception_errors);
  Serial.print("connection: ");
  Serial.print(packets[PACKET1].connection);
  //              Serial.println(" ");
Where is your signed data? Is it binary or text?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
Where are you images in you original post.
Please read the forum instructions on how to attach and display your files.
Tom..... :slight_smile:
