I have been trying to build an Arduino based Weather Station for a while. The main purpose of this project is to upload the DHT22´s readings to Xively´s website so I can see them when I am away from home. I think I do not understand the Xively API because the code gets compiled and uploaded to the Arduino but nothing is updated in the website so I do not know what is wrong with this sketch.
I require your help so I am able to finish this project, please feel free to modify the sketch.
#include <SPI.h>
#include <WiFi.h>
#include <HttpClient.h>
#include <Xively.h>
#include <DHT22.h>
#include <stdio.h>
//Setup a DHT22 instance
DHT22 myDHT22(7);
char ssid[] = "WIFISSID"; // your network SSID (name)
char pass[] = "WIFIPASSWD"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// Your Xively key to let you upload data
char xivelyKey[] = "l0wjcExUT54PATfrDdnsBSRirijNIHzIXTxFh3o3d7sBjo3W";
// Analog pin which we're monitoring (0 and 1 are used by the Ethernet shield)
int sensorPin = 7;
// Define the strings for our datastream IDs
char sensorId[] = "TEMPERATURE IS: ";
XivelyDatastream datastreams[] = {
XivelyDatastream(sensorId, strlen(sensorId), DATASTREAM_FLOAT),
// Finally, wrap the datastreams into a feed
XivelyFeed feed(750221065, datastreams, 1 /* number of datastreams */);
WiFiClient client;
XivelyClient xivelyclient(client);
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Serial.println("Starting single datastream upload to Xively...");
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWifiStatus();
DHT22_ERROR_t errorCode;
// The sensor can only be read from every 1-2s, and requires a minimum
// 2s warm-up after power-on.
delay(2000);
Serial.print("Requesting data...");
errorCode = myDHT22.readData();
switch(errorCode)
case DHT_ERROR_NONE:
Serial.print("Got Data ");
Serial.print(myDHT22.getTemperatureC());
Serial.print("C ");
// Alternately, with integer formatting which is clumsier but more compact to store and
// can be compared reliably for equality:
char buf[128];
sprintf(buf, "Integer-only reading: Temperature %hi.%01hi C",
myDHT22.getTemperatureCInt()/10, abs(myDHT22.getTemperatureCInt()%10),
Serial.println(buf));
case DHT_ERROR_CHECKSUM:
Serial.print("check sum error ");
Serial.print("C ");
case DHT_BUS_HUNG:
Serial.println("BUS Hung ");
case DHT_ERROR_NOT_PRESENT:
Serial.println("Not Present ");
case DHT_ERROR_ACK_TOO_LONG:
Serial.println("ACK time out ");
case DHT_ERROR_SYNC_TIMEOUT:
Serial.println("Sync Timeout ");
case DHT_ERROR_DATA_TIMEOUT:
Serial.println("Data Timeout ");
case DHT_ERROR_TOOQUICK:
Serial.println("Polled to quick ");
int sensorValue = analogRead(myDHT22.getTemperatureC());
datastreams[0].setFloat(sensorValue);
Serial.print("Read sensor value ");
Serial.println(datastreams[0].getFloat());
Serial.println("Uploading it to Xively");
int ret = xivelyclient.put(feed, xivelyKey);
Serial.print("xivelyclient.put returned ");
Serial.println(ret);
delay(15000);
