Hello,
I am having aproblem while connecting my arduino to both an external power suplly and the USB and I cannot figure out the solution. My set-up is as follows:
I am using an ATX power supply in combination with a voltage regulator as external power supply, because one of of my pressure sensors uses a 24V input I've connected the -12V and +12V of the ATX to my voltage regulator and set the voltage regulator to produce 7.5V, which is an acceptable voltage for the Arduino. Now all goes well, I can read the sensor output using an LCD display, but the second step is that I want to connect and monitor the output from the arduino with Matlab Simulink. Now when I connect the USB to my computer and I use the external power supply simultaneously the ATX shuts down.
My question is why does this happen? And more important, how can I solve this problem? Any help is very much appreciated.
