Hi all,
I need to play .wav files from a SD Card. I chose to use 22050Hz 8bits mono files.
I connected a TLC7226 parallel DAC to my Arduino Duemilanove. The datasheet is here : http://www.ti.com/lit/ds/symlink/tlc7226.pdf
I use the first DAC (it’s name DACA in the datasheet), that’s why I connected A0 and A1 to ground. The D0-D7 pins go to the Arduino, as /WR one. Voltage reference is 5V.
A speaker is connected between OUTA and ground, through a 100 ohm resistor and a 10µF capacitor.
The DAC works well, I can hear a square wave for instance. I also read data from my SD card. The problem is when I read a byte from the file and I write it on the DAC, I can’t recognize the music. There’s just “cracking sounds”.
Here is my code, sorry for the French :
#include <SD.h>
Connexion SD Card :
** MOSI (Violet) - pin 11
** MISO (Violet) - pin 12
** CLK (Gris) - pin 13
** SS (Blanc) - pin 4
File fichier;
byte octet;
int i;
int pin_D[8] = {A0, A1, A2, A3, A4, A5, 2, 3}; // Here is connected my DAC
int pin_Enable = 7;
void Ecrire_DAC(byte val) // Write a byte to the DAC
int i;
for(i = 0; i < 8; i++) // I know that way to write the byte is slow. It's just for debug.
digitalWrite(pin_D[i], bitRead(val, i));
digitalWrite(pin_Enable, LOW);
delayMicroseconds(5);
digitalWrite(pin_Enable, HIGH);
//Serial.print("Ecriture de ");
//Serial.println(val, HEX);
int i;
// Configuration du port série
// Configuration du DAC
pinMode(pin_Enable, OUTPUT);
pinMode(pin_D[i], OUTPUT);
Ecrire_DAC(0);
pinMode(10, OUTPUT);
if(SD.begin(10))
Serial.println("Initialisation de la carte SD reussie.");
Serial.println("Echec de l'initialisation de la carte SD.");
fichier = SD.open("22khz8b.wav");
if(fichier)
Serial.println("Ouverture du fichier reussie.");
Serial.println("Echec de l'ouverture du fichier.");
return;
fichier.seek(300); // make sure the pointer comes over the data
octet = fichier.read();
Ecrire_DAC(octet);
delayMicroseconds(45);
Even if the speed of the music will be very approximative, because I don’t wait precisely 45µs between each byte, I thought I can hear something.
Can someone help ?
Thanks
