I was programming a board with an ICSP wiring, and for months I could work with it, then suddenly the IDE started not recognizing the atmega328p, and the device signature is changing randomly
Already tried re-doing the wiring, changing the jumpers, changing the arduino board I was using to code (Arduino Uno), and I think the atmega is not dead, but with a clock problem while syncing. Searched the problem in various foruns and nothing helped.
To start with, please read this guide on how to insert images in your post. At the moment all I can see is a big blank section.
Are you using a designated ISP programmer, or are you using another Arduino? If you are using another Arduino, are you still able to upload a different sketch to it?
BJHenry:
Better now? Sorry I thought the image was ok
I’m using an Arduino, that works perfectly (but tried uploading codes with 2 UNOs and 1 nano, same response)
