Problem while pushing RFID tag data to server
I am trying to push the RFID tag information to thingspeak server via arduino wifi shield. i am not getting any error but my data is not pushing into server. Can anyone help me to resolve this?
#include <SPI.h>
#include <WiFi.h>
int val = 0;
char code[10];
int bytesread = 0;
char ssid = “UTStarcom-bsnl”; // your network SSID (name) //ITS OpEN
IPAddress server ( 184, 106, 153, 149 );
int status = WL_IDLE_STATUS;
// Initialize the Wifi client library
WiFiClient client;
// server address:
unsigned long lastConnectionTime = 0; // last time you connected to the server, in milliseconds
boolean lastConnected = false; // state of the connection last time through the main loop
const unsigned long postingInterval = 5*1000; // delay between updates, in milliseconds
String writeAPIKey = “6ZBMK0KXQTVS7FJW”; //ur thingspeak api???
//Initialize serial and wait for port to open:
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println(“WiFi shield not present”);
// don’t continue:
while(true);
String fv = WiFi.firmwareVersion();
if( fv != “1.1.0” )
Serial.println(“Please upgrade the firmware”);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid);
// wait 10 seconds for connection:
delay(10000);
// you’re connected now, so print out the status:
printWifiStatus();
int i, k = 0;
// if there’s incoming data from the net connection.
// send it out the serial port. This is for debugging
// purposes only:
if(Serial.available() > 0) { // if data available from reader
if((val = Serial.read()) == 10) { // check for header
bytesread = 0;
while(bytesread<10) { // read 10 digit code
if( Serial.available() > 0) {
val = Serial.read();
if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10) { // if 10 digit read is complete
Serial.println(code);
for (i = 0; i <= 10; i++)
k = 10 * k + code*; // print the TAG code*
  • bytesread = 0;*
  • if (client.available()) {*
  • char c = client.read();*
  • Serial.write(c);*
  • client.stop();*
  • // if there’s no net connection, but there was one last time*
  • // through the loop, then stop the client:*
  • if (!client.connected() && lastConnected) {*
  • Serial.println();*
  • Serial.println(“disconnecting.”);*
  • client.stop();*
  • if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {*
  • httpRequest(“field1=”+k);*
  • lastConnected = client.connected();*
// this method makes a HTTP connection to the server:
void httpRequest(String tsData) {
  • // if there’s a successful connection:*
if (client.connect(server, 80)) {
client.println(“GET /update?key=”);
client.println(writeAPIKey);
client.println("&");
client.println(tsData);
// note the time that the connection was made:
lastConnectionTime = millis();
  • else {*
  • // if you couldn’t make a connection:*
  • Serial.println(“connection failed”);*
  • client.stop();*
    void printWifiStatus() {
  • // print the SSID of the network you’re attached to:*
  • Serial.print("SSID: ");*
  • Serial.println(WiFi.SSID());*
  • // print your WiFi shield’s IP address:*
  • IPAddress ip = WiFi.localIP();*
  • Serial.print("IP Address: ");*
  • Serial.println(ip);*
  • // print the received signal strength:*
  • long rssi = WiFi.RSSI();*
  • Serial.print(“signal strength (RSSI):”);*
  • Serial.print(rssi);*
  • Serial.println(" dBm");*
