Problem while uploading arduino ever
I just get my arduino nano Every and it shows me error.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\48782\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM4
     Using Programmer              : jtag2updi
     Overriding Baud Rate          : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
boot-loader FW version: 1
firmware version: 1.07
hardware version: 1
S_MCU:
firmware version: 6.07
hardware version: 1
Serial number: 00:00:00:00:00:00
Device ID: JTAGICE mkII
AVR Part : ATmega4809
Chip Erase delay : 0 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 0
StabDelay : 0
CmdexeDelay : 0
SyncLoops : 0
ByteDelay : 0
PollIndex : 0
PollValue : 0x00
Memory Detail :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
       prodsig        0     0     0    0 no         61   61      0     0     0 0x00 0x00
       fuses          0     0     0    0 no          9    0      0     0     0 0x00 0x00
       fuse0          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse1          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse2          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse4          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse5          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse6          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse7          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       fuse8          0     0     0    0 no          1    0      0     0     0 0x00 0x00
       lock           0     0     0    0 no          1    0      0     0     0 0x00 0x00
       data           0     0     0    0 no          0    0      0     0     0 0x00 0x00
       usersig        0     0     0    0 no         64   64      0     0     0 0x00 0x00
       flash          0     0     0    0 no      49152  128      0     0     0 0x00 0x00
       eeprom         0     0     0    0 no        256   64      0     0     0 0x00 0x00
     Programmer Type : JTAGMKII_PDI
     Description     : JTAGv2 to UPDI bridge
     M_MCU hardware version: 1
     M_MCU firmware version: 1.07
     S_MCU hardware version: 1
     S_MCU firmware version: 6.07
     Vtarget         : 5.0 V
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.27s
avrdude: Device signature = 0x1e9651 (probably m4809)
avrdude: erasing chip
avrdude: reading input file "C:\Users\48782\AppData\Local\Temp\arduino_build_609508/Blink.ino.hex"
avrdude: writing flash (1120 bytes):
Writing | ################################################## | 100% 0.85s
avrdude: 1120 bytes of flash written
avrdude: verifying flash memory against C:\Users\48782\AppData\Local\Temp\arduino_build_609508/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\48782\AppData\Local\Temp\arduino_build_609508/Blink.ino.hex:
avrdude: input file C:\Users\48782\AppData\Local\Temp\arduino_build_609508/Blink.ino.hex contains 1120 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.16s
avrdude: verifying ...
avrdude: 1120 bytes of flash verified
avrdude: reading input file "0x01"
avrdude: writing fuse2 (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of fuse2 written
avrdude: verifying fuse2 memory against 0x01:
avrdude: load data fuse2 data from input file 0x01:
avrdude: input file 0x01 contains 1 bytes
avrdude: reading on-chip fuse2 data:
Reading | ################################################## | 100% 0.00s
avrdude: 1 bytes of fuse2 verified
avrdude: reading input file "0xC9"
avrdude: writing fuse5 (1 bytes):
avrdude: 1 bytes of fuse5 written
avrdude: verifying fuse5 memory against 0xC9:
avrdude: load data fuse5 data from input file 0xC9:
avrdude: input file 0xC9 contains 1 bytes
avrdude: reading on-chip fuse5 data:
avrdude: 1 bytes of fuse5 verified
avrdude: reading input file "0x00"
avrdude: writing fuse8 (1 bytes):
avrdude: 1 bytes of fuse8 written
avrdude: verifying fuse8 memory against 0x00:
avrdude: load data fuse8 data from input file 0x00:
avrdude: input file 0x00 contains 1 bytes
avrdude: reading on-chip fuse8 data:
avrdude: 1 bytes of fuse8 verified
avrdude done. Thank you.
Hi @kacper2. This is the normal and expected output from a successful upload. Congratulations!
Everything is fine, so you can now get back to having fun with your Nano Every.
Thank you very much!
