Problem while uploading bootloader
Can someone help me i have a problem wile burning bootloader on 3d printer motherboard exacly anet3d v1.7 and this error ocures:
Arduino:1.8.16 (Windows 10), Płytka:"Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
 Copyright (c) 2007-2014 Joerg Wunsch
 System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
 Using Port                    : COM3
 Using Programmer              : stk500v1
 Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xff
avrdude done. Thank you.
Błąd przy wgrywaniu bootloadera
At the end i will add i changed fusebits mayby this informatorom od important
Are the lights on the programmer blinking while attempting to load the bootloader?
There could be so many things that makes not possible to upload your program:
  1. Wires: Check twice your wires, better if you got an oscilloscope (look for the clock line).
  2. Reset line is functioning properly?
  3. Chip is functioning properly? Is it alive?
  4. Does your target board has power supply? Is this stable?
  5. Have you tried with another programmer, for example, another Arduino board set as programmer?
I don't know how it hapened but i leved that board for about a week or so and now when i was trying to burn bootlader there was no error
