problem whit the keypad and display
I have problem whit the keypad_I2C and liquidCristal_I2C When I use this part display gif the number 1 in display and system don’t work . I have change lib,s and Arduino software nothing works What is this for problem and how can I change this ?
You have some code you did not post. It does something that you did not explain. That differs in some unknown way from what you expect.
Easy. Expect the code to do what it actually does.
this code work normally
but a dont know what is wrong
al the code`s i send to the arduino within key have this problem now >
when a start arduino you see in the display popup the 1 and the software dont work.
a have put in lib
new arduino install, new windows install nothing seems to work .
#include<Wire.h>
#include <Keypad_I2C.h>
#define I2CADDR 0x3f
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = {0,1,2,3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4,5,6,7}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad_I2C customKeypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS, I2CADDR);
LiquidCrystal_I2C lcd(0x27,16,2);
void setup(){
//  Wire.begin( );
lcd.begin();
lcd.backlight();
  customKeypad.begin( );
void loop(){
  char customKey = customKeypad.getKey();
  if (customKey != NO_KEY){
    Serial.println(customKey);
    lcd.print(customKey);
See this
That is not in the code. Was the upload successful?
i have change win 7 to win 10 problem solve i had last update win 7 and the problem started i hope that i solve this problem thanks for suport
