Dear all,
For controlling four motors I have bought an Arduino uno and a motor board (Multi-motor from robot Power , http://www.robotpower.com/downloads/MultiMoto-v1_6_schematic.pdf). After downloading some code for this setup I tested the code while supplying the motor board with a 9 Volt battery, with Vin jumper connected. This worked fine. However, when I tried the same setup, but using the DC Power Jack(using an adapter from 230 to 12V, so it is supplied by the powergrid) did not work. The check light goes on, but the motors do not seem spin at all, even after changing the speed parameters in the code. Switching back to the 9V battery made it work again. But as the Robot will have to move around for a long period of time(11 hours) - over a limited distance - I would like to power the Arduino and the motor board using only the 12V adapter. Any suggestions?
Thanks for reading and thanks in advance. Also let me know if you need more information
Arthur
