Hello guys, im sorry for my english, because im latin
I have a project for mi carreer and i'm using the Arduino E Health Sensor Plataform; but i have a problem with the Ehealth.h library
I want to send 4 values to my windows application (WPF C#; (1 value from the glucometer and 3 values from the pulxio) but i can't send to my window app
I used Switch cases, serial available etc but nothing...
my code...
#include <eHealth.h>
int incomingByte = 0; // for incoming serial data
int val2=0;
String val3;
eHealth.readGlucometer();
Serial.begin(115200);}
uint8_t val=eHealth.glucoseDataVector[0].glucose;
val2=int(val);
val3=String(val2);
// send data only when you receive data:
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
if(incomingByte=='1'){
// say what you got:
Serial.print("I received: ");
Serial.println(val3);
else if(incomingByte=='2'){
and my windows code...
using System;
using System.Linq;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using Microsoft.Kinect;
using Microsoft.Kinect.Toolkit;
using Microsoft.Kinect.Toolkit.Controls;
using System.IO.Ports;
using System.Threading;
private void KinectTileButton_Click_1(object sender, RoutedEventArgs e)
myport.BaudRate = 9600;
if (!myport.IsOpen)
myport.DataReceived += myport_DataReceived;
myport.PortName = "COM11";
myport.Parity = Parity.None;
myport.DataBits = 8;
myport.StopBits = StopBits.One;
myport.Open();
myport.WriteLine("1");
txt_sys.Text = "";//puse esto para que me manttenga un solo valor
private void myport_DataReceived(object sender, SerialDataReceivedEventArgs e)
datetime = DateTime.Now;
string time = datetime.Hour + ":" + datetime.Minute + ":" + datetime.Second;
tensiometro = myport.ReadLine();
Dispatcher.BeginInvoke(new ThreadStart(() => txt_sys.AppendText(time + "\t" + tensiometro)));
private void KinectTileButton_Click_2(object sender, RoutedEventArgs e)
if (!myport.IsOpen)
myport.DataReceived += myport_DataReceived2;
myport.Open();
myport.WriteLine("2");
txt_dias.Text = "";//puse esto para que me manttenga un solo valor
private void myport_DataReceived2(object sender, SerialDataReceivedEventArgs e)
Dispatcher.BeginInvoke(new ThreadStart(() => txt_dias.AppendText(time + "\t" + tensiometro)));
private void KinectTileButton_Click_3(object sender, RoutedEventArgs e)
if (!myport.IsOpen)
myport.DataReceived += myport_DataReceived3;
myport.Open();
myport.WriteLine("3");
txt_pulso.Text = "";//puse esto para que me manttenga un solo valor
private void myport_DataReceived3(object sender, SerialDataReceivedEventArgs e)
Dispatcher.BeginInvoke(new ThreadStart(() => txt_pulso.AppendText(time + "\t" + tensiometro)));
please helpme...
