Problem with 2 way motor for arduino UNO R3 [Help!!!]
Hello everybody, i will like you to help me in a project than i'm curently working on.
So in a nutshell, this project is about creating a sort of drone but different and to do this i would like to use " drone " motor but not 3way motor with esc but just 2 way motor with a + and a - (like the one from the hubsan x4).
The problem is than i don't know if i can control the intesity/ speed of the motor directly from the arduino without using potetiometer or think like that. I add the idea to use transistor but i'm not sure.
*Thank you
Before adding any responses, please check here to see that the question hasn't already been answered.
TheGuyUnknown:
A brushless motor is the term, or BLDC - for RC craft these are usually sensorless BLDCs and require
a brushless ESC.
That's a coreless slotless dc motor
*Thank you
For small coreless/slotless you can use a single MOSFET with PWM, but you'll need a higher PWM rate I think
than the default on the Arduino - ie reprogram the relevant timer for a faster operation. As with any motor
driver circuit a free-wheel diode would be needed - look for examples of single-direction DC motor or relay control.
Most coreless/slotless motors are small and typically require an amp or two at most, and are usually
rated for direct operation from a single LiPo cell, ie about 4V.
