Hi all,
I wrote a wrapper for this APRS Modem/BeRTOS firmware ( MicroAPRS | unsigned.io ) ...
The Arduino wrapper are located at GitHub - stanleyseow/ArduinoTracker-MicroAPRS: Arduino Tracker (SVTrackR) for MicroAPRS modem
I wanted to write something similar to Radio Shield 2 Radio Shield 2 for Arduino, Argent Data Systems but completely open source ...
I needed 3 Serial port for the following functions :-
Pin 0,1 ( 9600) - connect to the APRS Modem to send commands and received decoded APRS packets from the radio
Pin 2,3 (9600) - connect to GPS module for GPS coordinates ( SoftwareSerial )
Pin 8,9 (57600) - connect to a FTDI Serial USB module for Debugging and send in commands purposes...
- pin 8,9 are using AltSoftSerial AltSoftSerial Library, for an extra serial port
Things that are not working (yet) are :-
- I could not copied the entire decoded APRS packet into a String or char array
I want to display the CALLSIGN ( the string after the SRC: ) and DATA: on the 20x4 LCD but I could not grab the entire row or only partial of the sample string below..
I suspect there are too many calls to other serial port ( e.g. GPS on Software Serial or Debug ) and therefore blocking this..
How shall I solve this Serial port issue with 3 Serial ports running at the same time...
Thanks
Stanley
The output of decoded messages from the APRS modem are as below :-
SRC: [9W2BBB-12] PATH: [9M2KKK-3] [WIDE1-1] [WIDE2-2] DATA: !/Lq@Yh1usP?DG/A=000273 13.6V 32CAPRS
SRC: [9M2CCC-3] PATH: [WIDE2-1] DATA: !/Lqluh1'q# st 11.8V 33C MAAAS VHF 144.3900MHz
SRC: [9W2AAA-0] PATH: [9M4RRR-3] [9M2TTT-1] [9M2KKK-3] [WIDE1-0] DATA: @050418z0300.35N/000004.61Ez
SRC: [9M2KKK-3] PATH: [WIDE2-1] DATA: !/Lqluh1'q# st 11.8V 33C MAAAS VHF 144.3900MHz
The decodeAPRS functions, the entire source codes are at the github URL stated above ...
void decodeAPRS() {
char c;
char endChar = '\n';
char endChar2 = '\r';
boolean storeString = true;
char callsign[12];
char path[60];
char data[100];
debug.println();
debug.print("Entering decodeAPRS (");
debug.print(millis());
debug.println(")");
while ( Serial.available() > 0 ) {
c = Serial.read();
// For debugging only
debug.print(c);
// If MAXBUFFER is reach, NULL terminate the string
if ( bufferIndex > maxBuffer ) {
charBuffer[maxBuffer] = 0;
storeString = false;
// Check for endChar and NULL terminate the string
if ( c == endChar || c == endChar2 ) {
charBuffer[bufferIndex] = 0;
if ( storeString ) {
charBuffer[bufferIndex++] = c;
// Save buffers into Strings if charBuffer is not blank
if ( !storeString && (!charBuffer[0] == 0) ) {
inBuffer = charBuffer;
if ( inBuffer != "" && !storeString ) {
debug.println();
debug.print("RF(");
debug.print(inBuffer.length());
debug.print("):");
debug.println(inBuffer);
// Check for first 3 char is SRC
if ( inBuffer.substring(0,3) == "SRC" ) {
int firstBracket = inBuffer.indexOf('['); // Anything in between [ and ] is the callsign & ssid
int secondBracket = inBuffer.indexOf(']');
//int secondColon = inBuffer.indexOf(':',secondBracket+1);
int secondColon = secondBracket+6;
// Do not use lastindexOf as the messaging uses : too
int thirdColon = inBuffer.indexOf(':',secondColon+1);
// Get the callsign
String decoded2 = inBuffer.substring(firstBracket+1,secondBracket); // Substring the callsign
decoded2.toCharArray(callsign,secondBracket+1-firstBracket-1); // Convert to char array
// Get the path
String decoded3 = inBuffer.substring(secondColon+2,thirdColon-5);
decoded3.toCharArray(path,decoded3.length()+1);
// Get the data
String decoded4 = inBuffer.substring(thirdColon+2,inBuffer.length());
decoded4.toCharArray(data,decoded4.length()+1);
debug.print("Callsign (");
debug.print(strlen(callsign));
debug.print("):");
debug.println(callsign);
debug.print("Path (");
debug.print(strlen(path));
debug.print("):");
debug.println(path);
debug.print("Data (");
debug.print(strlen(data));
debug.print("):");
debug.println(data);
lcd.clear();
lcd.setCursor(0,0);
lcd.print(callsign);
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
for ( int i=0;i<20;i++ ) { lcd.print(data[i]); }
// Print on Line 2
lcd.setCursor(0,2);
lcd.print(" ");
lcd.setCursor(0,2);
if ( strlen(data) < 40 ) {
for ( int i=20;i<strlen(data);i++ ) { lcd.print(data[i]); }
for ( int i=20;i<40;i++ ) { lcd.print(data[i]); } // Truncate data till 40 bytes
firstBracket, secondBracket, secondColon, thirdColon = 0;
} // endif SRC check
// clear the buffers after saving out all the variables like callsign, path and data
inBuffer = ""; // Clear the buffers
charBuffer[0] = 0; // Clear the buffers
bufferIndex = 0; // Reset the index
callsign[0] = 0;
path[0] = 0;
data[0] = 0;
} // end storeString
