Hi everyone.
After many prototype i decided to create a dedicated board based on the 32U4, self designed and created
But now i've trouble about flashing the chip. When i try to burn (with UNO and ArduinoISP sketch)
I've some message about wrong device signature. Sometimes it's 0x008000, sometimes 0xfffffff i've tried to change wires, board (same results with 2560 or pro micro) or crystal and nothing.
@johnwasser yup i agree and it's a litle bit better with a 10k+5v on reset. when i'm not 0x000000, i've the device signal. sometime it allow me to try to flash but fail the check step
i've soldered male pins on test point 30,29,31,24,17,16 (i placed them on side with the needed space between to plug it on a BreadBoard) and BB to uno with male to male wires
And in this way, VBUS is ONLY connected with VUSB (i connect all on my schema and this is the problem). On my pcb i've isolate VBUS by cutting way and now every time when i try, i can burn the bootloader
Testing pad is enough for temporary wire / solders. I'm agree it's fragile but when bootloader is burn (and usb test ok) i desolds them
