Problem with 4x20 Char Display
i've bought a display and wired all up like there:
this won't work and i tried the 8 Bit mode. dont work.
here is my wiring:
can you see what i've done wrong?
here is a shot, while it should display "Hello World":
Thanks!
Did you remember to change lcd.begin(16,2) to lcd.begin(20,4)?
are you certain it's a 20x4 display and not a 12864 display
We have to be able to unambiguously follow each wire from the LCD module to the Arduino. With wires that are the same colors you must spread them out. We also have to see the actual code that you are using, not the code that you think you are using.
That's a classic result when the LCD controller is not being initialized properly. This can be due to improper or defective connections and/or incompatible code. If you cant give us a better picture then we need a description of where each of your LCD connections goes.
Don
EDIT: It looks like you may have a 'cold' solder joint on pin 4.
That will have no effect on whether the 'hello, world!" message will be displayed or not.
Don
There are not enough pins for a GLCD, and the screen has the wrong proportions for a 128x64.
Don
johnwasser:
Yes
abrookfield:
No
Where can i find out?
floresta:
Don
What do you mean exactly?
Thanks for your help!
I mean that the other poster is wrong and that you do have a 20x4 display.
If you really want to get your display working you should consider my reply #3?
Don
floresta:
Don
okay, i resolder all pins and try it again. Is there another reason for this error? - i've copy & pasted the code from the tutorial and changed the constructor for the 8 bit mode, cause it wont work in the 4 bit mode. Should it work in 4 bit mode too?
do you have one of the blue wires in the tx pin? looks like maybe you do
i've resoldered all pins - still not working.
abrookfield:
the RX & TX Pins are unused.
i've wired the data-pins:
Display pin 7 => Arduino pin 9
Display pin 14 => Arduino pin 2
other pins:
Display pin 1 => GND
Display pin 2 => 5V
Display pin 3 => Poti (Contrast, works)
Display pin 4 => Arduino pin 12
Display pin 5 => GND
Display pin 6 => Arduino pin 11
Display pin 15 => 5V
Display pin 16 => GND (with resistor for LED Backlight, works)
my code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 9, 8, 7, 6, 5, 4, 3, 2);
   // set up the LCD's number of columns and rows:
   lcd.begin(20, 4);
   // Print a message to the LCD.
   lcd.print("hello, world!");
   lcd.setCursor(0, 1);
   // print the number of seconds since reset:
//   lcd.print(millis()/1000);
I've made a video:
duration: 14s
The Display displays nonsense :s
That's not what I see in your photograph or your video.
Don
floresta:
Don
WOW! yeah!
thanks!
that was the problem!
i <3 you!
The solution to your problem emphasizes the reason for this:
"We have to be able to unambiguously follow each wire from the LCD module to the Arduino. ... We also have to see the actual code that you are using ..."
Don
I don't know about you guys but MY Crystal Ball Broke when I asked it if I was the most handsome guy in the world...
Doc
